pilar
TMR0 as external pulse counter |
Posted: Fri Dec 17, 2010 9:13 am |
Hi, anyone can tell me how I can use the TMR0 to count external pulses ? I am using a pic18f452 to 20Mhz. I need to count the number of pulses every 1 second.
This is part of my code but I do not think it is wrong
#include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
int pulsos;
void main(){
setup_counters (RTCC_EXT_H_TO_L, RTCC_DIV_1);
while (TRUE){
set_timer0(0);
pulsos = get_timer0();
Posted: Fri Dec 17, 2010 9:34 am |
Start by thinking what 'AKA', and 'or' means. Look at the include file for your processor.
What does "SETUP_COUNTERS() or SETUP_TIMER_0()," mean?.
What do you think happens, if you set timer0 (AKA the RTCC) to use an external clock, and then a line later, set it to use an internal clock?. Which do you think it'll end up using?.
Remove one line, and you may have a chance.....
bkamen
Joined: 07 Jan 2004 Posts: 1615 Location: Central Illinois, USA
Posted: Fri Dec 17, 2010 9:35 am |
read the section on the CCP module. (if that PIC has one. if not, look at the datasheet for one that does.)
