ffotsch
spi_xfer error() on v.115 PCH? |
Posted: Wed Dec 15, 2010 6:09 am |
I am using a PIC 18f2550 with two spi slaves, one uses hardware spi and the other uses software spi. Here are my use statements:
#use spi(MODE=3, DI=PIN_a2, DO=PIN_a3, CLK=PIN_a1, BITS=16, STREAM=adxl)
#use spi(FORCE_HW,MODE=3,BITS=8,STREAM=eeprom)
I am using the spi_xfer(), here is an example of use:
spi_xfer(adxl,0x32|0xc0,8);//set read and multiple byte bits with b11000000 mask
x_sample.u_byte[0]=spi_xfer(adxl,0x00,8);
This code complied fine and worked fine until I upgraded to version 4.115, the compiler now generates this error on every spi_xfer() statement.
"Error 99 wrong pin for H/W"
Is my use statement wrong? Am I overlooking something or is this perhaps a bug in the new release?
Thanks! |
collink
Re: spi_xfer error() on v.115 PCH? |
Posted: Wed Dec 15, 2010 9:52 am |
I looked at the data sheet for that chip and it appears that the following are the hardware pins for SPI:
B0 = DI
B1 = Clock
C7 = DO
You are trying to use A1 - A3 for this. The hardware SPI must use the proper pins which is what the compiler is telling you. I have no idea why previous versions would not have complained. Maybe they were silently falling back to software SPI. |
ffotsch
Posted: Wed Dec 15, 2010 12:33 pm |
Yes, those are the hardware pins for SPI. However, it is my understanding and experience that spi can also be done in software without using the hardware pins. I have two spi devices on the same chip, the chip has only one H/W spi port. Thus, one of the two is H/W and the other is software. The H/W spi is connected to the pins you refer to and the S/W spi is connected to a1, a2, and a3. My understanding is that it is ok to use S/W spi without using the H/W spi pins on the controller.
Thanks for your reply. |
collink
Posted: Wed Dec 15, 2010 12:44 pm |
ffotsch wrote: | Yes, those are the hardware pins for SPI. However, it is my understanding and experience that spi can also be done in software without using the hardware pins. I have two spi devices on the same chip, the chip has only one H/W spi port. Thus, one of the two is H/W and the other is software. The H/W spi is connected to the pins you refer to and the S/W spi is connected to a1, a2, and a3. My understanding is that it is ok to use S/W spi without using the H/W spi pins on the controller.
Sorry, I didn't see that the two statements had different streams so they should be different. You do seem to be using the proper stream. What happens if you reverse the two SPI definition lines so that the hardware one is defined first? |
Posted: Wed Dec 15, 2010 4:08 pm |
If it worked in a previous version and it doesn't work in the latest version,
and there is no CCS explanation in the Readme.txt of different usage,
then it's likely a bug and needs to be reported to CCS.
In the vs. 4.115 announcement email that I got, they said this:
Quote: | Recent changes include:
4.115 PCD SPI defines SPI_XMIT... have been modified to operate the same as PCM and PCH
4.115 A number of device database errors have been fixed
4.115 A PIC24 bug with &= on 32 bit operands is fixed
4.115 New #USE TIMER library added |
My guess is that they made a mistake when they upgraded the database
for the 18F2550 with respect to the hardware SPI module.
If you own the compiler, email CCS support about this bug. |
