Issue with internal oscillator on PIC12F675
victor_constantin
PostPosted: Wed Dec 15, 2010 3:41 am     Reply with quote
Hello guys,
I'm trying to create a blink led program for a 12f675 using CCS. Problem is i can only get the led's to register to the first state in the program, thus, no blinking, just on/off depending on the first state of the pin declared in the main loop.
I tested this with a blinkled program in MPLAB and it works fine so the issue is with CCS, not the PIC. The code is below. Any ideas would be much apreciated.
#include "D:\Pic\test2.h"
   port_a_pullups(TRUE);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
int foo;
  foo=1;
   while (foo==1)
          output_high(PIN_A5);
          output_low(PIN_A4);
          output_high(PIN_A3);
          output_low(PIN_A2);
          output_high(PIN_A1);
          output_low(PIN_A0);
          output_low(PIN_A5);
          output_high(PIN_A4);
          output_low(PIN_A3);
          output_high(PIN_A2);
          output_low(PIN_A1);
          output_high(PIN_A0);
Below is the header file
#include <12F675.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOCPD                    //No EE protection
#FUSES NOPROTECT                //Code not protected from reading
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPUT                    //No Power Up Timer
#FUSES BANDGAP_HIGH
#FUSES RESERVED                 //Used to set the reserved FUSE bits
I couldn't really find anything to solve this on the forum, please point me in the right direction if there is a thread i missed that could help.
Wayne_
PostPosted: Wed Dec 15, 2010 5:30 am     Reply with quote
I expect your 500ms delay is more like 500 seconds! (exageration)
You are using INTRC (internal rc clock) and you have #use delay(clock=20000000)
I doubt very much the internal clock on that pic can run at 20MHz!
I am having trouble accessing the datasheet at the moment so someone else will have to confirm this.
victor_constantin
PostPosted: Wed Dec 15, 2010 5:38 am     Reply with quote
Yes, you are right, it's a 4Mhz oscillator. However, i now changed that setting to #use delay(clock=4M) but to no avail.
Geps
PostPosted: Wed Dec 15, 2010 6:41 am     Reply with quote
int foo;
  foo=1;
   while (foo==1)
What's the purpose of this? It looks messy and overcomplicates the program.
   while (TRUE)
Try changing
#FUSES MCLR
to
#FUSES NOMCLR
Geps
PostPosted: Wed Dec 15, 2010 6:42 am     Reply with quote
Another point, you don't need
in both header and source file - unless using two sets of delays. Since you're not, just delete one.
victor_constantin
PostPosted: Wed Dec 15, 2010 5:09 pm     Reply with quote
Sorry for the late reply and thanks for the answers. However, i wasn't able to solve the issue, the program still runs in the same way. Any other ideas?
From what i've gathered so far, the problem is with the internal clock, the PIC seems to get hung as soon as it hits the delay instruction.
PostPosted: Wed Dec 15, 2010 5:20 pm     Reply with quote
1. What is your CCS compiler version ? It's a 4-digit number (only)
and is given at the top of your .LST file, which will be in your project
directory after a succesful compilation of your project.
2. Do you have a pull-up resistor on the MCLR pin of the PIC ?
What is the value of the resistor ?
3. What is the Vdd voltage of the PIC ?
4. Do you have a series resistor in your LED circuit ?
Example:
pin      330 ohms      LED
GP2  ----/\/\/\/------->|----
                          -----  Ground
My advice is, don't try to to light up 5 LEDs. Disconnect all, except one.
victor_constantin
PostPosted: Wed Dec 15, 2010 5:27 pm     Reply with quote
1. Version is 4.104
2. No resistor in series with the MCRL pin. What would be the correct value? What would be the correct way to wire it?
3. Vdd voltage is 5.5V
4. Yes, there is a resistor. As i've stated in the first post, the circuit is functional, tested with another program in MPLAB. Only two LED"s connected at the current time but it works with all connected.
PostPosted: Wed Dec 15, 2010 5:39 pm     Reply with quote
If you're using the NOMCLR fuse, you don't need the MCLR resistor.
What pins do you have LEDs attached to on the PIC ? What pin numbers ?
Why is your Vdd set at +5.5v ? Why not use the usual voltage of +5.0v ?
PostPosted: Wed Dec 15, 2010 6:20 pm     Reply with quote
I don't have time to wait for your reponse on the LED pins.
I just want to get this done.
I installed vs. 4.104 of the compiler. I used a Pickit2 Low Pin Count
board for this test. I removed the 16F690 from the board's socket and
installed a 12F675 in the upper portion of the socket. I added a jumper
wire from pin RA2 on the board (GP2) to an LED on the board.
I then compiled and loaded this program with the Pickit2. It works.
It blinks the LED:
#include <12F675.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOMCLR
#define GP0   PIN_A0
#define GP1   PIN_A1
#define GP2   PIN_A2
#define GP3   PIN_A3
#define GP4   PIN_A4
#define GP5   PIN_A5
   output_high(GP2);  // Blink LED on pin GP2
   output_low(GP2);
victor_constantin
PostPosted: Thu Dec 16, 2010 3:18 am     Reply with quote
Hello, sorry for the late response. I managed to fix it after all, the problem was indeed with the NOMCLR. Thanks alot guys.
