killerbee
program error |
Posted: Sun Dec 12, 2010 10:32 am |
I'm using 16F877A and I'm blocked in how to copy an entered value from a keyboard to an array already declared empty. But it won't work because in debugging mode the array is always taking the value ' ' (space). I've tried everything but nothing... a little help please!!!
#include "16F877A.h"
#use delay(clock=10M)
#byte PORTB= 0x06
#byte PORTC= 0x07
#byte TRISB= 0x86
#byte TRISC= 0x87
#byte PORTD= 0x08
#byte TRISD= 0x88
#bit E =PORTC.0
#bit RS=PORTC.1
#bit C1=PORTD.0
#bit C2=PORTD.1
#bit C3=PORTD.2
char texte[28]="veuillez saisir le code ";
char Tvrep[13]="code correct";
char Tfrep[15]="code incorrect";
int i;
char touche=' ';
void envoie_commande(char commande)
E=0;
RS=0;//mode commande
PORTB=commande;
E=1;
delay_us(50);
E=0;
void envoie_caractere(char caractere)
E=0;
RS=1;//mode affichage
PORTB=caractere;
E=1;
delay_us(50);
E=0;
#int_timer0
void clavier()
touche=' ';
PORTD=0x08;//Selection de la ligne A
if(C1==1){touche='1';while(C1==1);}
if(C2==1){touche='2';while(C2==1);}
if(C3==1){touche='3';while(C3==1);}
PORTD=0x10;//Selection de la ligne B
if(C1==1){touche='4';while(C1==1);}
if(C2==1){touche='5';while(C2==1);}
if(C3==1){touche='6';while(C3==1);}
PORTD=0x20;//Selection de la ligne C
if(C1==1){touche='7';while(C1==1);}
if(C2==1){touche='8';while(C2==1);}
if(C3==1){touche='9';while(C3==1);}
PORTD=0x40;//Selection de la ligne D
if(C1==1){touche='*';while(C1==1);}
if(C2==1){touche='0';while(C2==1);}
if(C3==1){touche='#';while(C3==1);}
void init_LCD()
delay_ms(15);//attendre le démarrage du LCD
envoie_commande(0x3C);//Mode 8bits, 2ligne, 5*10 font
delay_ms(5);
envoie_commande(0x0E);//display on, Corseur on, blink off
delay_ms(5);
envoie_commande(0x01);// clear dispaly
delay_ms(5);
void rotation(int texte[26])
int A;
A=Texte[0];
for(i=0;i<25;i++) texte[i]=texte[i+1];
texte[24]=A;
int T[4]={1,2,3,4};
int Ts[4];
int cmp,j,code;
TRISB=0x00;
TRISC=0xFC;
TRISD=0x87;
setup_timer_0 (RTCC_DIV_128|RTCC_INTERNAL);
init_LCD();
func1:
while(touche==' ')
disable_interrupts(INT_TIMER0);
envoie_commande(0x80);
for(i=0;i<24;i++) envoie_caractere(texte[i]);
delay_ms(200);
rotation(texte);
delay_ms(5);
for(cmp=0;cmp<4;cmp++)
//envoie_commande(0x80);
func2: if (touche!=' ')
envoie_caractere('*');
touche=' ';
Ts[cmp]=touche;
else {goto func2;}
for (j=0;j<4;j++)
if (Ts[j]==T[j])
code=1;
else{
code=0;
while(true)
if(code==0)
//! else{break;}
for(i=0;i<24;i++) envoie_caractere(Tfrep[i]);
rotation(texte);
goto func1;
for(i=0;i<24;i++) envoie_caractere(Tvrep[i]);
rotation(texte);
Posted: Sun Dec 12, 2010 2:02 pm |
You are not declaring an array.
Single inverted commas, declare a single character.
Declare your array, as:
char touche[5];
Make it large enough to store the charcters you want, _and_ remember the space for the terminating '\0', if you want to use it as a string. Add the characters to this, and remember to add the termination.
