starfire151
multiple ADC channel conversions with timer int |
Posted: Sat Dec 11, 2010 2:20 pm |
I searched the posts related to this but did not see anything specific to this question...
Is it possible to start a conversion on two ADC channels and then, a time delay later, read them out? For instance
from the background:
set_adc_channel(0);
set_adc_channel(1);
and then enable a timer interrupt which interrupts a sufficient time later:
from the timer interrupt service routine:
x = read_adc(0);
y = read_adc(1);
From what I've seen in the data sheet and what has been posted, most of the time the set_adc_channel() and read_adc() operations are done sequentially. Is there any way to get the channels to convert at the same time? |
bkamen
Posted: Sat Dec 11, 2010 2:35 pm |
It depends on the PIC.
Typically the answer is "no". You need to read the datasheet for the device you want to use very carefully.
For example: most PIC18's only have 1 sample/hold and 1 converter. However, the 18Fxx31 has 2 sample/holds and 1 converter.
This means triggering a sample can cause both sample/hold units to sample, then the converter performs it's work on S/H1 and then S/H2.
You get 2 samples at interrupt time (if you have it set that way - but there are more options), but they were arrived at sequentially.
Some of the higher end PIC's (like the 16bit/32bit PIC's) have more than one converter. So they could deliver more than one channel worth of values for a given sample trigger.
If you're using PIC16's or 18F's, most likely you can only do one conversion on one channel at a time.
starfire151
Posted: Sat Dec 11, 2010 3:11 pm |
Excellent. This gives me something to go with.
Thanks for the replies. |
bkamen
Posted: Sat Dec 11, 2010 3:31 pm |
Right - but to reiterate,
Dual Sample/Hold -- SINGLE converter.
So that means triggering the A/D will cause both S/H's to initiate their sample... then they hold. This gives 2 channels "captured" in time.. Then the converter will being with S/H unit #1 to provide a conversion... then it will do number 2. (you can actually configure the unit to then auto-switch to another 2 channels and do another conversion set -- while the result FIFO can be set to Interrupt on 1, 2 or 4 results)...
Have fun --- searching the right PIC can sometimes be a little work - but worth it...
gpsmikey
Posted: Sat Dec 11, 2010 3:36 pm |
Quote: | Have fun --- searching the right PIC can sometimes be a little work - but worth it... |
Until you then discover that the perfect solution to your problem is a "future product" ... I think I have been there a few times !!
mikey _________________ mikey
bkamen
Posted: Sat Dec 11, 2010 4:58 pm |
gpsmikey wrote: | Quote: | Have fun --- searching the right PIC can sometimes be a little work - but worth it... |
I talked with my local Microchip rep and got PIC18F46J11 44qfp samples before they were available anywhere else... for prototyping, it was perfect.
Never hurts to ask "how much in the future" a PIC is.
