3x4 Keypad and 2x16 LCD
Guest3
PostPosted: Fri Apr 17, 2009 2:16 am     Reply with quote
Hi guys !
I am using one simulator software for simulating LCD and keypad.
http://tinypic.com/view.php?pic=29cxg6b&s=5
In this simulator I can define port's for each key.
ON/OFF is used as key press simulation.
So I took the flex_kbd driver as example for setting the port connection.
flex_kbd.c
#define col0 PIN_E1
#define col1 PIN_A5
#define col2 PIN_C0
#define row0 PIN_E0
#define row1 PIN_C2
#define row2 PIN_C1
#define row3 PIN_E2
I set first key ( col0,row0) but when I run this program nothing happens:
#include <16F877.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
#include <LCD.c>
#include <flex_kbd.c>
   char k;
   lcd_init();
   kbd_init();
   lcd_putc("\f *LCD is ON* ...\n");
   while (TRUE) {
      k=kbd_getc();
      if(k!=0)
        if(k=='*')
          lcd_putc('\f');
          lcd_putc(k);
What's wrong with this code ?
PostPosted: Fri Apr 17, 2009 11:39 am     Reply with quote
Two weeks ago, you asked this same question. You were given good
answers to solve the problem. You ignored those answers.
Here is the thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=38401
Your schematic in your link above still has the same problem.
You are using pull-down resistors on the row pins, but they should be
pull-up resistors.
Guest3
PostPosted: Tue Apr 21, 2009 3:01 am     Reply with quote
You are absolutely correct. I asked the same question because i have to wait for new hw design. So i was thinking to make the program on the simulator. I apologize for "double posting" but it was in good manner.
John P
PostPosted: Tue Apr 21, 2009 10:13 am     Reply with quote
And I'll say again what I said in the other thread--you're wasting components if you use resistors at all. Use Port B and enable the internal pull-ups. That's exactly what they're for.
PostPosted: Wed Apr 22, 2009 3:58 am     Reply with quote
I agree with you and i will remove resistors in the next hardware design. In the meantime how to configure the program to read the keypad presented by simulator.
I can not change simulator settings, so i can't remove resistors.
All i can change are the ports settings.
gonlo82
View user's profile Send private message Send e-mail MSN Messenger
Suggestions for Proteus simulations
PostPosted: Fri Dec 10, 2010 3:44 pm     Reply with quote
i've tried a lot of time to run this example in Proteus_7.2_SP6 and i don´t success. The last time I've copied your code and it was compiled without errors. I copied the diagram too and the lcd doesn´t show anything.
could you give me some help?
I m working for me in electrical troobleshooting. Pic's Matter interest me a lot to improve my skills.
PostPosted: Fri Dec 10, 2010 5:27 pm     Reply with quote
I don't have Proteus so there's no way for me to help you.
In other words, if Proteus has some bug, how can I see it ?
But I'll try anyway. Post your schematic.
gonlo82
The wiring diagram
PostPosted: Mon Dec 13, 2010 5:13 am     Reply with quote
I send you the wiring diagram from proteus environment.
I attach you the code too. (this is an example from a pdf found in taringa website useful for amaters.)
#include <16F876.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES PUT                      //Power Up Timer
#FUSES NODEBUG//,NOPBADEN                  //No Debug mode for ICD
#define LCD_TYPE       2
#define use_portb_lcd TRUE
#define use_portb_kbd TRUE
#include <lcd.c>
#include <kbd.c>
#define LCD_ENABLE_PIN  PIN_C2
#define LCD_RS_PIN      PIN_C1
//#define LCD_RW_PIN      PIN_B6
#define LCD_DATA4       PIN_C4
#define LCD_DATA5       PIN_C5
#define LCD_DATA6       PIN_C6
#define LCD_DATA7       PIN_C7
   char k;
   int x;
   lcd_init();
   kbd_init();
   port_b_pullups(TRUE);
   lcd_putc("\fEscriba...\n");
   while (TRUE)
   k=kbd_getc();//lcd envia caracteres en ASCII a k
   x=k-48;// se resta 48d=(0Ascii)=30hex
      if(k!=0)
         if(k=='*')
         lcd_putc('\f');
         lcd_putc(k);//imprime cararter
         printf(lcd_putc,"\f Car=%c",k);//imprime cararter
         printf(lcd_putc,"\f Car=%u",k);//imprime valor ASCII
         printf(lcd_putc,"\f Num=%u",x);//imprime valor numerico del caracter
         lcd_putc("\fListo...\n");
[img]
http://img697.imageshack.us/img697/9002/kbdlcdpic16f877.jpg
[/img]
PostPosted: Mon Dec 13, 2010 2:52 pm     Reply with quote
Your schematic shows that pins A and B on the keypad are connected
together by mistake. Edit your schematic and fix it.
What is this code doing in your program ? Your schematic shows all
connections go to Port B. Why do you have this code above, which shows
mostly connections to Port C ? Delete all of the above lines.
gonlo82
LCD+KEYBORD PIC16F876 ON PROTEUS
PostPosted: Mon Dec 13, 2010 8:25 pm     Reply with quote
The mistake on Proteus is corrected and the lines related with port c are erased. Do you have the same result during simulation? Persist the same error when the lcd doesn't show the value of each key.
In case of a bug in Proteus, do you have any suggestion to solve it?
PostPosted: Tue Dec 14, 2010 2:00 pm     Reply with quote
Post your compiler version and I'll test the ex_lcdkb.c program in
hardware for your version.
gonlo82
Proteus_7.2_SP6the version
PostPosted: Tue Dec 14, 2010 2:41 pm     Reply with quote
the version is Proteus_7.2_SP6. I will follow trying because known people could fix it but in Assemble code.
Thanks from now
PostPosted: Tue Dec 14, 2010 2:43 pm     Reply with quote
Not Proteus. The CCS compiler version.
