Comparator Interrupt
ogimy
PostPosted: Sun Dec 05, 2010 7:14 pm     Reply with quote
Can tell me definition of comparator interrupt? or give me
suitable links... Very Happy
PostPosted: Sun Dec 05, 2010 10:44 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=26861
ppyote
PostPosted: Mon Dec 06, 2010 5:15 pm     Reply with quote
Could you give an example using the 18F2550 pic comparators? I do not get them to run, but in the range of 16f I have no problem in putting in place.
Sorry my English, but not all the good that I would like.
thanks
ogimy
PostPosted: Mon Dec 06, 2010 7:45 pm     Reply with quote
I have make this program to simulate the function of an comparator interrupt.
Situation:
a. PIC will continuously toggle LED at port RB1, RB2 and RB3, and toggle buzzer ON and OFF in sequence every 1 sec.
b. When interrupt occur, all LED and buzzer will automatically turn OFF, and only turn ON LED RB4.
c. After 2 sec, all sequence function back as normal.
Can someone check this code and show which part should put comparator interrupt?
#include <16f877a.h>
#device adc=8
#use delay (clock= 20000000)
#fuses hs,noprotect,nowdt,nolvp
#byte PORTa=5
#byte PORTb=6
#byte PORTc=7
#byte PORTd=8
#byte PORTe=9
Void main()
Set_tris_b(0b0000000);
Setup_port_a(ALL_ANALOG);
Setup_adc(ADC_CLOCK_INTERNAL);
do
portb=0b00000010;
portb=0b00000100;
portb=0b00001000;
output_high(pin_D0);
delay_ms(2000);
output_low(pin_D0);
delay_ms(2000);
if (input(pin_D1)==1)
Portb=0b00010000;
delay_ms(2000);
else(input(pin_D1)==0)
portb=0b00000010;
portb=0b00000100;
portb=0b00001000;
delay_ms(2000);
output_low(pin_D0);
delay_ms(2000);
While(1);
PostPosted: Tue Dec 07, 2010 12:50 pm     Reply with quote
Here's a comparator example for the 18F4550 with some hysteresis.
(I don't have an 18F2550, but the 18F4550 is in the same PIC family).
When you turn the trimpot on pin A0 (from 0v to 5v, slowly), the LED
will turn on when you go higher than 2.5 volts. When you then turn
the trimpot the other way (from 5v to 0v, slowly), the LED will go off
when you go below 2.3 volts. This hysteresis prevents noise on the
input signal (on pin A0) from causing the comparator to flip around
when it's near the threshold voltage. The hysteresis is created by
the code in the isr which changes the threshold level.
#include <18F4550.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#define VREF_LOW_THRESHOLD   11      // Vref = 2.3 volts
#define VREF_HIGH_THRESHOLD  12      // Vref = 2.5 volts
#define LED_PIN  PIN_B0
#byte CMCON = getenv("SFR:CMCON")
#INT_COMP
void isr()
int8 temp;
if(C1OUT == 1)
   output_high(LED_PIN);  // LED on
   setup_vref(VREF_LOW | VREF_LOW_THRESHOLD);
   output_low(LED_PIN);  // LED off
   setup_vref(VREF_LOW | VREF_HIGH_THRESHOLD);
// Read CMCON register to clear the "mismatch" condition.
temp = CMCON;
int8 value;
setup_comparator(A0_VR_A1_VR | CP1_INVERT);
// Initialize the LED.
if(C1OUT == 1)
value = CMCON;  // Clear mismatch condition.
clear_interrupt(INT_COMP);  // Clear interrupt flag
enable_interrupts(INT_COMP);  // Enable interrupts
ppyote
PostPosted: Wed Dec 08, 2010 5:37 pm     Reply with quote
Hello again, I have the version of the 4104 ccs if I recuerto and the program has not since before I work ... is not in the simulator or the proboard
which compiler version are you?
will put the code below in my program ...
thanks again
#include <18f2550.h>
#fuses HS,MCLR,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL1,CPUDIV1,NOVREGEN,NOPBADEN
#word cncom=0x0fb4
#word portb=0x0f81
#word cvrcon = 0x0fb5
#use standard_io(a)
#int_comp
void interrupcion()
   if(!c1out){
      portb=0xff;
   else portb=0x00;
void main(){
   set_tris_b(0x00);
   set_tris_a(0xFF);
   setup_comparator(A0_A3_A1_A2);
   enable_interrupts(int_comp);
   enable_interrupts(global);
   portb=0x00;
while(1){}
PostPosted: Wed Dec 08, 2010 6:10 pm     Reply with quote
I tested my program with versions 4.114 and 4.104 on a PicDem2-Plus
board and it works OK with both versions.
I don't want to test your program. I only wanted to post a working
demonstration program.
ogimy
PostPosted: Fri Dec 10, 2010 9:49 am     Reply with quote
I have rewrite the program. I try compile into ccs, its ok. But can the programmer check the code it will run on hardware and follow the situation above? Because I don't have hardware to check.
#define LEDPIN1  PIN_B1
#define LEDPIN2  PIN_B2
#define LEDPIN3  PIN_B3
#define LEDPIN4  PIN_B4
#INT_COMP
void isr()
int8 temp;
if(C1OUT == 1)
      output_high(LEDPIN1); // 1 LED ON
      output_high(LEDPIN2); // 1 LED ON
      output_high(LEDPIN3); // 1 LED ON
      output_high(pin_d7);  // BUZZER ON
      output_low(LEDPIN1); // 1 LED Off
      output_low(LEDPIN2); // 1 LED Off
      output_low(LEDPIN3); // 1 LED Off
      output_low(pin_d7);  // BUZZER OFF
temp = CMCON;
int8 value;
setup_comparator(A0_VR_A1_VR);
if(C1OUT == 1)
   output_high(LEDPIN4);
   output_low(LEDPIN4);
//clear_interrupts(INT_COMP);    // Clear interrupt flag
ppyote
PostPosted: Sat Dec 11, 2010 6:30 am     Reply with quote
I know, I just wanted to ask you to revise it in case my code was wrong
as I said, my English is not very good. About what the version of ccs, you wondering if perhaps the version I was using had some bug ...
thanks again for your help
