make8() not working
kda406
make8() not working
PostPosted: Thu Dec 09, 2010 2:02 pm     Reply with quote
4.114, PIC18F8722
Make8() will not compile when a variable is used as the offset. Here is an example I created that will not compile:
void somefunction(void) {
   int8 iData[4];
   int32 lPortBit[] = { 0x00000010,0x000000020,0x00000040,0x00000080,0x00000100,
      0x00000001,0x00000002,0x00000004,0x00000008 };
   int8 iCnt,iOffset;
   for(iCnt=0;iCnt<9;iCnt++) {
      for(iOffset=0;iOffset<3;iOffset++)  iData[iOffset] = make8(lPortBit[iCnt],iOffset);
      fprintf(TERM,"%02X\n\r",iData[0]
This would make iData[3] contain the MSB and iData[0] contain the LSB of the int32.
*** Error 108 "AB12-IO.c" Line 121(39,46): Invalid parameters to built in function ::
where line 121 is the line with make8() in it.
The CCS manual does not indicate if offset must be a constant. Am I doing something wrong?
Thanks,
Kyle
PostPosted: Thu Dec 09, 2010 2:12 pm     Reply with quote
I don't think a variable parameter is supported for the offset.
kda406
PostPosted: Thu Dec 09, 2010 2:32 pm     Reply with quote
Thanks, that was my conclusion, but I don't see why they would not. It seems sophomoric to do:
      iData[0] = make8(lPortBit[iCnt],0);
      iData[1] = make8(lPortBit[iCnt],1);
      iData[2] = make8(lPortBit[iCnt],2);
      iData[3] = make8(lPortBit[iCnt],3);
My professors would have laughed at me for forgetting how to do loops. Wink
Thanks,
Kyle
PostPosted: Thu Dec 09, 2010 3:52 pm     Reply with quote
The problem is down to the nature of the function. It uses the simplest approach, to select the byte _efficiently_ at compile time. You can do it with a loop, using a union, or casting an int8 pointer to the memory you want to transfer, _but_ the variable version, will probably be about 3 or 4 times the size of all four of the single byte transfers, and slower too...
