Displaying large numbers on 2 or 4 line LCD
Ringo42
PostPosted: Thu Dec 09, 2010 2:12 pm     Reply with quote
I'm considering a project that will have an LCD display, either 2 line or 4 line. What I would like to do is when setting up the unit the LCD will act like a regular lcd (using flex_lcd), but when idle it will display the time in big numbers like an alarm clock. Has anyone done anything like this before? I guess I could build a boatload of custom characters for the top and bottom of each number, but that would take forever. There must be a better way, any thoughts?
Ringo
Ringo Davis
PostPosted: Thu Dec 09, 2010 2:16 pm     Reply with quote
You could adapt Scott Edward's BASIC program(www.seetron) that he created for serial LCDs about a decade ago...
PostPosted: Thu Dec 09, 2010 2:24 pm     Reply with quote
See BPP-420L on this page:
http://www.seetron.com/slcds.htm
Another example of large chars built from several custom chars:
http://www.modtronix.com/product_info.php?products_id=274
Ringo42
PostPosted: Thu Dec 09, 2010 2:25 pm     Reply with quote
As far as I know his source is not available, unless it is somewhere on his site and I missed it.
Ringo Davis
Ringo42
PostPosted: Thu Dec 09, 2010 2:28 pm     Reply with quote
Yes that is exactly what I want to do, but without buying a $40 serial LCD. I want to make sure there is not code out there (like flexlcd) before I start defining a bunch of custom characters.
Ringo
Ringo Davis
PostPosted: Thu Dec 09, 2010 3:01 pm     Reply with quote
ok... google 'big_nums.bs2' for Scott's program...
yeesh..it dates back to mid 90s !!!
bkamen
PostPosted: Thu Dec 09, 2010 4:34 pm     Reply with quote
Building the custom block chars isn't all that hard.
I think I have an HD44780 setup someplace for making a lock/unlock, target symbol for an LCD in C.
Let me know if you want it,
-Ben
