How I can HEX to hyperterminal
pilar
PostPosted: Tue Nov 30, 2010 4:58 pm     Reply with quote
Hi, I need to send the Hyperterminal a block of hex codes, how I can do this?
I am use this code, but its does not work, what is my error?
   for (k = 0; k<538; k++)
         printf("%x",read_ext_eeprom(0,k,));
PostPosted: Tue Nov 30, 2010 5:09 pm     Reply with quote
Please gives us the entire program along with software version.
There are several ways it could 'not work'.
Power supply problems...
board layout...
The eeprom data is corrupt, the eeprom address is wrong(hint what type is variable k).
The serial configuration for the PIC is in error..
either software(baud,bits,etc) or hardware(MAX232 chip mising ?)
The PC and Hyperterminal are not configured correctly
As you can see that's only a few of the reasons it 'doesn't work'.
The more information, specifically -what- doesn't work, will allow others to repsond to your question.
PostPosted: Tue Nov 30, 2010 5:14 pm     Reply with quote
'k' must be declared as an 'int16' variable, because 538 is greater than
the maximum 'int8' value of 255. Also, printf must use "%lx" to display an int16.
All of this is in the CCS manual.
Look in the section on "Basic and Special Types", and in the section on printf.
And to others, please, we don't need 4-5 posts saying how bad
Hyperterminal is. One of those per month is enough, lol.
pilar
PostPosted: Tue Nov 30, 2010 5:41 pm     Reply with quote
Hi PCM programmer,
I am sorry, maybe I explained wrong!!!, I can see in the hyperterminal the block of codes sent but was converted to an ASCII format, but I need that the hyperterminal receive these codes as the PIC have been sent, for example if the PIC send the 0x32 in the hyperterminal should show the character "2", if the PIC send the code 0x49 in hyperterminal should show the "I" and so on, what I have to do to accomplish this?
example
PIC       Hypert.
0x32      2
0X43      C
0x49      I
PostPosted: Tue Nov 30, 2010 5:51 pm     Reply with quote
Download the manual:
Look in the section on printf. You want to send a character.
What format string should you use ? It's listed in the manual.
Keep a copy of the CCS manual on your Windows desktop.
Humberto
PostPosted: Tue Nov 30, 2010 6:04 pm     Reply with quote
I never used Hyperterminal for known and justified reasons.
If you are reading ASCII char in your monitor may be also because it was setted for show that OR it can't
show in another format.
The best choice is to try with another communication editor. See this:
http://www.ccsinfo.com/forum/viewtopic.php?t=42307&highlight=teraterm
http://www.ccsinfo.com/forum/viewtopic.php?t=34226&highlight=teraterm
and many others...
Regards
dbotkin
PostPosted: Tue Nov 30, 2010 6:35 pm     Reply with quote
Hyperterminal is indeed a POS, but that's not your (biggest) problem. As PCM Programmer suggested, download and read the manual for help with the printf() function. In your case, a simple putc() would work as well:
long int k;
for (k = 0; k<538; k++) {
    putc(read_ext_eeprom(k));
pilar
PostPosted: Tue Nov 30, 2010 10:24 pm     Reply with quote
Hi dbotkin,
Very Happy it is exactly that I was looking, THANK YOU!!!
