RS-232
steppermotor
RS-232
PostPosted: Sat Nov 27, 2010 10:13 pm     Reply with quote
Hello All,
I'm a bit desperate right now, could anyone point me to simple C code for sending and receiving rs-232 on a PIC16f877a.
Thanks.
arunb
RE:
PostPosted: Sun Nov 28, 2010 5:11 am     Reply with quote
Read the CCS example in help file, it receives a data, data is incremented and printed to PC.
putc(getc()+1);
its the simplest and the best for basic diagnostics...
Read also the hardware connection details using the MAX 232 IC.
thanks
a
bkamen
PostPosted: Sun Nov 28, 2010 11:55 am     Reply with quote
also look in the CCS Help/Manual for the preprocessor command #USE RS232 .
there's a lot of links to functions and examples at the bottom of that page.
PostPosted: Sun Nov 28, 2010 12:16 pm     Reply with quote
Read the forum everyday. You'll learn a lot.
http://www.ccsinfo.com/forum/viewtopic.php?t=40001
Here is a post that describes how to setup Hyperterminal:
http://www.ccsinfo.com/forum/viewtopic.php?t=9253&start=1
Teraterm is a better terminal program than HyperTerminal.
Here are instructions for downloading and installing TeraTerm:
http://www.ccsinfo.com/forum/viewtopic.php?t=39388&start=18
Here is the CCS FAQ article on RS-232 problems:
http://www.ccsinfo.com/faq.php?4
Here is a schematic of a MAX232 circuit:
http://web.ukonline.co.uk/j.winpenny/pic/rs232x.gif
Note that if you're using a MAX232A, then you should use 0.1 uF
capacitors, instead of the 1 uF caps.
bkamen
PostPosted: Sun Nov 28, 2010 1:02 pm     Reply with quote
ANYTHING is better than Hyperterminal. ;)
I use PuTTY (http://www.chiark.greenend.org.uk/~sgtatham/putty/)and RealTerm (http://realterm.sourceforge.net/)
Both have their handy features.
Cheers,
Ben
gpsmikey
PostPosted: Sun Nov 28, 2010 2:20 pm     Reply with quote
RealTerm seems to be a cool app (just installed it). As observed, "ANYTHING is better than Hyperterm". Be sure and note their comment if you are using a USB to Serial adapter (since lots of newer motherboards no longer have serial ports on them)
"If you are using an FTDI usb adaptor you need to install the FTDI driver first"
Note also on the link to TeraTerm is close, but there is a newer version out from what PCMProgrammer provided (as of Aug 30, 2010).
mikey
mikey
bkamen
PostPosted: Sun Nov 28, 2010 2:33 pm     Reply with quote
USB->Serial can be summed up in one thought:
"Always Suspect until proven to work on THIS (and only this) computer/project/thingie/whatever."
I have great luck (90%) of the time with Iomega USB-RS232 adapters.... but for some reason (and the reasons are probably many) -- a hard serial port is still king for all applications - Period.
Go figure. USB is how old now?
-Ben
p.s. USB/Bluetooth/etc are perfect examples of how layers of abstraction add complexity that eventually WILL bite one in the hind-quarters. KISS principle wins.
PostPosted: Sun Nov 28, 2010 2:41 pm     Reply with quote
I've got of those USB<-> RS232 adapters here.One works the other fails miserably,go figure.And this is with a simple llopback connector on it !!!
I hate USB( Useless Serial Bus), give me a REAL comport ! With REAL interrupts, real time control is possible!
I second Realterm...seems to be stable and reliable.
bkamen
PostPosted: Sun Nov 28, 2010 2:48 pm     Reply with quote
I like RealTerm, but I've noticed if I leave it running for a long time (hours and hours) -- it slows down and becomes unresponsive. I have to kill it and restart it and then it's fine for hours again.
Go figure. (shrug)
Otherwise it's very handy.
-Ben
