sandrini
PIC24F and ADC expression |
Posted: Sun Nov 28, 2010 8:39 am |
Please,
I'd like a help with this code below...
The ad_c value shows the value 63 when the ADC value is 1023.
The expression "ad_c = (ad_c * 3300)/1023;" return a wrong value.
Code: | #include <24FJ128GA010.h>
#device ADC = 10
#fuses HS,PR,NOWDT,NOPROTECT
#use delay(clock=8000000)
#include "LCD8B.c"
int32 ad_c;
void main() {
lcd_ini();
setup_adc_ports(sAN0, VSS_VDD);
setup_adc(ADC_CLOCK_DIV_128 | ADC_TAD_MUL_31);
SET_ADC_CHANNEL(0);
while(true) {
ad_c = READ_ADC();
printf(lcd_escreve,"\fADC = %ld",ad_c);
gpsmikey
Posted: Sun Nov 28, 2010 10:36 am |
Couple of things come to mind here
- there needs to be a delay after you set the channel before you can read and
- I would consider modifying the print routine to display both the raw count from the ADC and the result.
You indicate you get the wrong result for a given count, but you don't say how you determined that really was the count. I may have missed something (have not had coffee yet), but it doesn't look like an overflow since you are using int32.
Also, you don't indicate what you are using for the "temp" reading, but most of the linear temp sensors have an offset you need to subtract out as well (500mv=0degC for example). You might also want to consider using signed so if the resulting temp is negative it doesn't blow up
mikey _________________ mikey
Joined: 01 Jul 2010 Posts: 9458 Location: Greensville,Ontario
Posted: Sun Nov 28, 2010 11:32 am |
also..
if the 3300 and 1023 are 'constants', have the compiler do the work !
have a line like
const int midterm= 3300 / 1023
it might save some time as division takes a lot of time compared to mutlply |
sandrini
Posted: Sun Nov 28, 2010 12:00 pm |
gpsmikey temtronic and I would like to thank ...
In my code, the correct is "printf (lcd_escreve," \ fADC =% ld ", ad_c);"
I do not know what is happening, but when I use the expressin "ad_c = (ad_c * 3300) / 1023" ... The result is completely wrong.
I use this expression with the PIC16 and PIC18 and have no problems.
I decided to use the suggestion of Temtronic, so I'm dividing 'ad_c' by '3 .22 (3300/1023), in which case the result is correct.
But still many thanks for the tips. |
FvM
Posted: Sun Nov 28, 2010 1:13 pm |
Results in midterm value of 3, so it's only a roughly correct result.
Actually, there's no plausible reason why the original code shouldn't work, except you're using a buggy PCD version. Which version has been used? |
sandrini
Posted: Mon Nov 29, 2010 4:56 am |
I'm using version 4.108 and I also believe it is a bug in the compiler.
I have no problems with the PIC 16F and / or 18F, only now I started working with the PIC 24F, I noticed these problems. |
FvM
Posted: Mon Nov 29, 2010 5:08 am |
You said, it's the calculation not the ADC built in function. But I checked the calculation to be performed correctly in V4.107 and also recent PCD versions (don't have 4.108 installed at present). I would trace the program execution in debugger to find, where it fails. |
