Hi guys
I want to generate 2 software pwm channels using 12F675. I think I have good idea about how to make software pwm using a timer interrupt.
And also I'm planning to use external interrupt channel on 12F675.
My question is will these two interrupt interfere with each other?
I mean while generating PWM, occurrence of a external interrupt will stop executing timer interrupt routine?
Is there any way to use this two interrupts without interfering each other? So I can use external interrupt same time without stopping PWM generation?
thank you.
My compiler version is 4.084
Posted: Thu Nov 18, 2010 8:47 pm
If you get an External interrupt, any other interrupts that occur after
that moment will be blocked until the External interrupt has finished
being handled by the compiler.
