Convert minutes in hours
Posted: Tue Nov 16, 2010 6:17 am
Hi there i need your help..!!!
i built a counter 6 digit the fist 4 digit is hour the last 2 one is minute
0000:00
i have two variable add together to add time in the counter...prob is if i have like 58 minutes and want to add 3 minutes the result on display is 0000:61
i want to convert this in hour...0001:01
i tried:
if (minutes == 60)
hours++; x1 = 1;
60 work!!!
61 or more dont work (past true) i've tried > or >= instead of ==
same prob...
and if i have 55 minutes and i want to add 20 make 75...should be
0001:15
Thanks for help!!!!!
