alfredo
HELP with the pointers |
Posted: Mon Nov 15, 2010 11:16 am |
I've this problem and I don't know what to do:
#use standard_io(A)
#define use_portb_lcd TRUE
float halo[10];
int halo2(halo)
float a=2.14;
float b=1.1;
int i;
for(i=0;i<10;i++)
halo[i]=a*b;
main()
printf(lcd_putc,"%f",halo[1]);
return(0);
the error is
Quote: | Error 51 line 15(1,3) : previous identifier must be a pointer halo[i]=a*b;
I hope your answers, please ..merci |
Posted: Mon Nov 15, 2010 1:18 pm |
Your problem is mixing global names and local names.
A function definition, should contain the _local_ name and type for varibles passed to it. Local definitions _override_ global ones.
You use the name (without type) for a global variable. in the function definition, so in this function, the variable 'halo', is _not_ a pointer to an array. Hence the error....
John P
Posted: Mon Nov 15, 2010 6:14 pm |
Instead of
int halo2(halo)
try
void halo2(float *halo)
By the way, your program doesn't call the halo2() function. I assume you wrote it with the intention of using it! |
