fredmatic
Joined: 14 Mar 2009 Posts: 5 Location: motor city, usa
Clock problems with 18F44J11 |
Posted: Mon Nov 15, 2010 3:38 pm |
I have a simple setup with a PIC18F44J11. I am using a 16 mhz crystal and trying to use the processor in HS mode.
The system starts up properly, but all timing functions seem be off by an order of magnitude.
Processor setup is:
#use delay(clock=16000000) // Frequency set at 16Mhz
#fuses HS,NOWDT,NOPROTECT,XINST,STVREN,IESO,NOIOL1WAY
#fuses PRIMARY,NOCPUDIV
#use standard_io(b)
my interrupt routine is:
#int_TIMER3
void TIMER3_isr(void) // 10 msec timebase
set_timer3(15536);
gClkUpdate = 1;
g10msTimer1++;
g10msTimer2++;
in main I have:
setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1); // Set up timer 1 (counter);
set_timer1(0); // Reset timer1 counter
setup_timer_3(T3_INTERNAL | T3_DIV_BY_8);
set_timer3(15536);
enable_interrupts(INT_TIMER3);
As I understand it, the timer input is OSC/4, so the input to Timer3 is 4,000,000 hz, which divided by 8 would be a count rate of 500Khz. Timer3 then counts 50,000, (from 15536 to rollover, 0000).
Instead, it is almost 20 seconds between interrupts and I haven't a clue as to why this is.
Any help would be greatly appreciated.
thanx in advance..... mark |
Posted: Mon Nov 15, 2010 3:43 pm |
#use standard_io(b)
The extended instruction set is not supported by CCS. Using it will result
in erratic program operation. Change the fuse to NOXINST. |
fredmatic
Posted: Mon Nov 15, 2010 4:18 pm |
I changed the fuse and no change. I am kinda going crazy on this one.
With the fuse selections, I should have the HS/16mhz selected, right?
I have been programming the PIC3, dsPIC33' and PIC24F's for seven years and this is the first venture into the PIC18's.
Oh well, gotta keep trying. Thanx |
Posted: Mon Nov 15, 2010 5:28 pm |
This works. This provides a 5 Hz signal on Pin C4, which is correct.
I don't have an 18F44J11 but I have a PIC in the same family. I tested
this program with compiler vs. 4.114. If it doesn't work, make sure you
really have a 16 MHz crystal installed, and also make sure it's really
running at 16 MHz. When I was testing this, I accidently had a 4 MHz
crystal installed and it made me wonder what was happening for a while.
Then I fixed it and it started running correctly.
#include <18F24J11.h>
#fuses HS,NOWDT
#int_TIMER3
set_timer3(15536);
output_toggle(PIN_C4);
set_timer3(15536);
fredmatic
Posted: Mon Nov 15, 2010 5:53 pm |
I'll give it a try. The 24J11 is the same processor, just a wee bit less memory.....ok, no PMP or deep sleep, but I don't use those anyhow.
I'll give it a try....
thanx |
fredmatic
Posted: Mon Nov 15, 2010 5:57 pm |
Actually, that should give you a 10Hz output....just remember, the your LED is 0.1 on, 0.1 off.
mark ![Shocked](images/smiles/icon_eek.gif) |
Posted: Mon Nov 15, 2010 6:16 pm |
With a 16 MHz oscillator, the instruction clock is 4 MHz. The Timer3
prescaler reduces that to 500 KHz. Then Timer3 is preset to 15536,
so it counts 50K clocks before it rolls over and generates an interrupt.
So 500 KHz / 50K = 10 Hz interrupt rate. I'm toggling pin C4 in the isr,
so the frequency of output waveform will be 10 Hz / 2 = 5 Hz. It only
generates 1/2 cycle of the output waveform per interrupt. |
fredmatic
Posted: Mon Nov 15, 2010 8:04 pm |
you're right...thanx |
