PIC 18F2620 and SD-Card FAT
Goto page 1, 2  Next
Prefekt
PostPosted: Thu Nov 11, 2010 11:18 am     Reply with quote
I try the ex_fat.c program from the example directory.
But I cant do any operation on the sd card. I have a 1GB SD-Card and formated it with fat32. But every operation brings me an error.
I'm only change the include File for the pic...
Does anybody an Idea?
Best regards
Volker
andrewg
PostPosted: Thu Nov 11, 2010 8:22 pm     Reply with quote
Have a look at these two threads and see if they help:
CCS FAT driver bugfix!
CCS SD/MMC driver MBR support
Andrew
Prefekt
PostPosted: Fri Nov 12, 2010 12:06 pm     Reply with quote
I have made the changes and I can now connect the SD Card from the pic. But I can't see the created directories and files on the card, if I read this on my pc!
And if I make a directory for file on the pc I can't see this on the pic!
I can put the sd card of the pic and reset the pic. Then I put the card into the slot from pic and I found my directories and fiels again. But on Windows I can't see nothing. And the winhex is also found nothing? How can it be?
Best regards
Volker
andrewg
PostPosted: Fri Nov 12, 2010 9:31 pm     Reply with quote
Have you got the FAT16/32 matched? You must compile the correct variant for the cards you're using.
Andrew
Prefekt
PostPosted: Sat Nov 13, 2010 2:23 am     Reply with quote
yes, the card is formatted with fat32 and in the source file I set #define fat32.
How I can see directories, where there a nothing on the card? Are this information stored in the eeprom from the pic?
Best regards
Volker
andrewg
PostPosted: Sat Nov 13, 2010 3:50 am     Reply with quote
Have you looked at the ex_fat.c example file? That covers everything you would want to do with an SD card.
Andrew
Prefekt
PostPosted: Sat Nov 13, 2010 4:11 am     Reply with quote
I use the ex_fat.c example.
It works good, after the changes you have posted.
I have formatted the card on a pc, but I can't see the fiels an directories on the card. If I create a directory on the card with pc I'cant see this on the PIC.
It seems that the pc and the pic use to different cards, but it's the same!
I need this for my datalogger *ahhhh*
Best regards
Volker
Prefekt
PostPosted: Sat Nov 13, 2010 4:17 am     Reply with quote
Has anybody a working code with the driver files?
I don't know what's wrong, and don't know what I can do!
Volker
andrewg
PostPosted: Sat Nov 13, 2010 9:04 pm     Reply with quote
If you're sure it's otherwise working, then all I can think of is that the PC is accessing one partition and the PIC is accessing another. If you've put in my MBR support code (see link in post above) then try commenting out all but one of the mmcsd_check_part() function calls. Do that for each in turn to force the use of a specific partition.
Andrew
Prefekt
PostPosted: Sun Nov 14, 2010 12:35 pm     Reply with quote
Hi Andrew,
Good idea with the test function. I will try it tomorrow and post the effect...
I have try it more often and on the pc I see only the files that I created on my pc and on the pic I see only the files, that I created with the pic.
Is it possible that the values are stored in the PIC memory??
Volker
Prefekt
PostPosted: Mon Nov 15, 2010 2:08 pm     Reply with quote
Andrew,
the test has nothing, same as ever :-(
In the mmcsd.c file is this: #if USE_SW_ONLY
But the compiler say that it's unknown!!!
I found my directories, that I have generade with pic with the winhex on the position:
00074A50, 00074A80
The directory from the pc is on:
00400060
On the pic, I see the directorys from the pic only
On the pc, I see the directorys from the pc only
SD Card formated specs:
Bytes per Cluster: 4096
Bytes per Sektor: 512
FAT: FAT32
Here are 3 pics....
the first is the boot sector from the card:
the second is the 'pc_data' directory on the card from the pc (i can't see it on the pic)
the third is the 'data001' directory on the card from pic (i can't see it on the pc)
Why the directory on different places.
Volker[/url]
andrewg
PostPosted: Tue Nov 16, 2010 10:06 am     Reply with quote
You are expected to #define that to either 0 or 1. 1 for a software SPI, 0 for a hardware SPI.
As for the rest, your first picture shows a partition boot sector not a master boot record (MBR). My MBR code should be calculating g_mmcsdPartitionOffset as zero (no master boot record), so that's one thing to check.
All I can suggest after that is to work out yourself what the PIC should be reading off the SD card and confirm those values, i.e. after fat_init, do all the global variables contain the expected values?
Andrew
Prefekt
PostPosted: Wed Nov 17, 2010 12:40 am     Reply with quote
Andrew,
For the USE_SW_ONLY, I'm wondering that the compiler not know this, it's in the original mmcsd.c file!
I have read at wikipedia, there is written, that the mbr is starts at 0x000 and the MRB signature is on 0x01FE ' 55' 'AA', this is on it. Where you see that is not the MRB? Sorry I'm new with the FAT File System :-)
I have checked my files, mmcsd.c and fat.c for your changes. And I use the ex_fat.c sample. What could happened? I go crazy!
Do you have as simple code to the your function?
Best regards
Volker
andrewg
PostPosted: Wed Nov 17, 2010 8:48 am     Reply with quote
An MBR and partition boot record have the same signature at the same place (55 AA at 01FE). To tell the difference, you look at where the partition table should be and check the four entries there. That's what my MBR support code does. If you trace through my code, you'll see that the tests fail for all four possible partition table entries, and so the MMCSD code assumes the partition starts at address zero, which it does in your case, since the card is not partitioned.
Andrew
Prefekt
PostPosted: Thu Nov 18, 2010 2:29 pm     Reply with quote
@andrewq
Ah I understand, the check function can't find the place where the partion table should be an so decide the function, It's not a MBR...
So how I create the MBR on the sd card? It was formatted with windows...
I have bought the driver from Andrew Smallridge, because I must finished the project. (www.brushelectronics.com) and it works perfect. The driver is very easy to use and there are samples to test it.
But now, I can search how the error ist and will post the results here.
Special thanks to andrewg ...
Regards
Volker
Goto page 1, 2  Next
Page 1 of 2
