PIC12F675 + Sleep + External Interrupt Wakeup
heisenberg
PostPosted: Fri Nov 12, 2010 2:36 pm     Reply with quote
I'm doing a bias lighting system for my monitor and TV using two PIC12F675s and some LEDs and a light sensor. Two different push buttons control whether to turn the system on or off depending if the room is dark. I want to put the MCUs into sleep mode instead of having it poll the push buttons and use the ON button as an external interrupt to kick it out of sleep and loop back to the beginning of the code. I don't understand how to use sleep and external interrupts properly.
Flow:
[nothing happening]->[sleep]->[room is dark and ON button pushed]->[exit sleep mode, turn on LEDs]->[off button pushed, turn off LEDs]->[sleep]...
Schematic:
#include <12f675.h>
#fuses INTRC_IO, NOWDT, NOMCLR
#bit INTF = 0xB.1
//PIN_A0 = LED
//PIN_A1 = LIGHT
//PIN_A2 = ON
//PIN_A3 = OFF
//PIN_A4 = CONTROL
//PIN_A5 = LED
   int on, off, adc;
   //ext_int_edge(H_TO_L);
   //INTF = 0;
   //enable_interrupts(INT_EXT);
   //enable_interrupts(GLOBAL);
      setup_adc_ports(sAN1);
      set_adc_channel(1);
      adc = read_adc();
      delay_ms(10);
      //ON button pushed
      if(input(PIN_A2) == 0)
         on = 1;
      //OFF button pushed
      else if (input(PIN_A3) == 0)
         off = 1;
         on = 0;
         off = 0;
      //ON button pushed and room is dark
      if((adc < 50) &&  (on == 1))
         output_HIGH(PIN_A5);
         output_HIGH(PIN_A4);
         output_HIGH(PIN_A0);
      //OFF button pushed or room is bright
      else if ((off == 1) || (adc > 50))
         output_LOW(PIN_A5);
         output_LOW(PIN_A4);
         output_LOW(PIN_A0);
      //Waiting.....go to sleep unless ON button is pushed
         //INTF = 0;
         //sleep();
The code for the second PIC isn't important.
PostPosted: Fri Nov 12, 2010 3:21 pm     Reply with quote
See the examples by ckielstra in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=28447
Humberto
PostPosted: Fri Nov 12, 2010 3:43 pm     Reply with quote
If you have achieved to run this project properly, see ex-wakep.c in the examples folder, it should be
very straightforward to implement in your application.
Regards
