TCP2UART project in CCS
Manel28
PostPosted: Thu Nov 04, 2010 5:33 am     Reply with quote
Does anyone know if there is some TCP2UART project migrated to CCS? I would like to have some example code to implement a ethernet to serial converter based on PIC18F25j10 and ENC28j60. Thanks
andrewg
PostPosted: Thu Nov 04, 2010 8:29 pm     Reply with quote
I've done this (for a commercial project, so I can't share the source), but as projects go, it was pretty easy. It was a couple of days work from scratch.
Start with the Telnet RFC0854. Telnet basically streams raw bytes back and forth on a TCP socket, except that it uses 255 as an 'escape' character to enable extra functionality. CCS TCPIP examples 13 and 13b cover TCP client/server comms.
Then read RFC2217. That's serial port emulation extensions to Telnet. It defines extra 'escape' commands to switch baud rates and flow control.
Andrew
bkamen
PostPosted: Fri Nov 05, 2010 8:28 am     Reply with quote
I did the same thing (with an octal UART) but was also part of a paid project, so I can't share the source. I used RAW sockets which is a little easier and a telnet interface that allowed configuring the ports speeds and such.
It's pretty straight-forward.
I started with the CCS TCPIP Stack and just used that as a template. Study the example -- in a sense, everything you need is in there.
Manel28
PostPosted: Fri Nov 12, 2010 4:00 am     Reply with quote
The problem is that this is my first experience with ethernet in PICs and I don't know exactly how to organize the hole thing. It would be pretty easy to buy a commercial device but I want to learn something by myself. Some example code would be nice. Anyway I have decided to bring it forward Smile.
bkamen
PostPosted: Fri Nov 12, 2010 2:17 pm     Reply with quote
Example code?
Microchip's library. It has an example to model.
The CCS TCPIP library is Microchip's TCPIP library V3.75.
In fact, with a little cutting and pasting, I'd bet the Microchip files containing the UART "stuff" could be easily pasted over to CCS.
-Ben
andrewg
PostPosted: Fri Nov 12, 2010 9:30 pm     Reply with quote
A first step could be to compile the CCS examples 13/13b I mentioned above and see if you can get them working. Your PC will have a telnet client you can use for testing. I forget exactly what the example do, but just getting your PIC to echo typed characters back would probably be enough for starters.
FYI, if you do decide to implement Telnet serial port (RFC2217), then a handy PC app is http://www.hw-group.com/products/hw_vsp/index_en.html which creates a virtual COM port to your device.
Andrew
