18F2580 Digitals
rwskinner
18F2580 Digitals
PostPosted: Tue Nov 09, 2010 4:01 pm     Reply with quote
I have an 18F2580 that has been working properly for a couple of years but now I'm having a hard time getting PortA.0 to act properly for a digital input. It's always high when I read it.
PortA.1 seems to work fine.
I do have setup_adc_ports(No_Analogs) set in my code.
Any ideas what I'm missing out on?
Thanks,
Richard
PostPosted: Tue Nov 09, 2010 4:17 pm     Reply with quote
1. Post a (complete) little test program that shows the problem.
It should have the #include for the PIC, #fuses, #use delay(), any other
#use statements that are needed, all variable declarations, and a main().
It should compile with no errors.
2. What is your compiler version ?
3. Describe your test circuit, or post a link to a schematic of it.
4. Describe the signal on pin A0. Is it a constant DC level ? What is the
voltage level ?
rwskinner
PostPosted: Tue Nov 09, 2010 4:49 pm     Reply with quote
Port A.0 goes to ground with a 10k resistor. A dip switch pulls it up to 5 volts. Same for A.1
#include <18F2580.h>
#FUSES HS                       //High Speed Clock
#FUSES BORV43                   //Brownout reset at 2.1V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOLVP
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES BBSIZ2K                  //2K words Boot Block size
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled
   Port_B_PullUps(False);
   Setup_adc_ports( NO_ANALOGS );
   Setup_ADC(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //Test LED on C4
  output_high(Pin_C4);
 Delay_ms(1000);
 output_low(Pin_C4);
 While (True)
  //Turn LED On when A.0 is ON
  if (input(Pin_A0)==1)
    output_high(Pin_C4)
    output_low(Pin_C4);
If I use Pin_A1 then it works fine.
PostPosted: Tue Nov 09, 2010 4:51 pm     Reply with quote
Where is the #use delay() statement ?
rwskinner
PostPosted: Tue Nov 09, 2010 4:58 pm     Reply with quote
PCH 4.114
I typed it instead of copy paste.
PostPosted: Tue Nov 09, 2010 5:37 pm     Reply with quote
It works for me. I compiled your program with vs. 4.114 and ran it on
a 18F2580 on a PicDem2-Plus board (non-Rohs version). This board
has a 5K trimpot on pin A0. I used it supply the test voltage for pin A0.
I don't have an LED on pin C4, so I jumpered it over to pin B0 where there
is an LED.
I slowly turned the trimpot so pin A0 would go from 0v to 5v. I put a
voltmeter on pin A0 to see the voltage. When I got to 1.23v, the LED
turned on and stayed on all the way up to 5v. Going back down, it
went off at about 1.23 volts again, and stayed off as I took the voltage
down to 0v. It's working.
rwskinner
PostPosted: Tue Nov 09, 2010 5:44 pm     Reply with quote
Looks to be a hardware issue. My older models work fine, my new models off the production line seem to have an issue on the pull down resistor, such as open....
Thanks for your help PCM. I never would have thought every new module I pulled off the shelf would have this issue.
Richard
