Generating PWM , Problem
buAliSina
PostPosted: Wed Nov 03, 2010 7:28 pm     Reply with quote
Hi , wrote this code but nothing comes out !!!! driving me mad plz help
#include <16F628A.h>
#FUSES NOWDT, INTRC, NOPUT, NOPROTECT, NOBROWNOUT, MCLR, NOLVP, NOCPD
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,49,1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(40);
   setup_vref(FALSE);
   while (TRUE) {} ;
Mad
Just a dead body ignores Human suffering
PostPosted: Thu Nov 04, 2010 12:12 pm     Reply with quote
1. What is your compiler version ?
2. What is your testing environment ?
a. Proteus ?
b. Factory manufactured development board ?
c. Home-built board ?
d. 3M breadboard ?
3. Have you ever made this PIC do anything, such as blinking an LED ?
In other words, do we know that that PIC, the board, and the compiler
are basically working, and the problem is only with PWM ?
Last edited by PCM programmer on Thu Nov 04, 2010 12:47 pm; edited 2 times in total
buAliSina
Help
PostPosted: Thu Nov 04, 2010 12:42 pm     Reply with quote
hi thanks for reply
1. version CCS 4.084 PCWH
2. both Proteus and home-build board ( that i know its ok )
3. blinking LED works fine , but the problem is PWM signal
PostPosted: Thu Nov 04, 2010 12:57 pm     Reply with quote
I took your posted code, with no changes, and compiled it with vs. 4.084.
I ran it on a 16F628A on a PicDem2-Plus board. I looked at pin B3 with
an oscilloscope and I see negatives pulses, about 10 us duration, with
a high time of about 40 us. The oscilloscope's built-in frequency counter
says 19.75 KHz. It's working. The PIC is running at +5v.
Here's the top of the generated .LST file:
CCS PCM C Compiler, Version 4.084, xxxxx       04-Nov-10 11:50
               Filename: pcm_test.lst
               ROM used: 50 words (2%)
                         Largest free fragment is 1998
               RAM used: 6 (3%) at main() level
                         6 (3%) worst case
               Stack:    0 locations
buAliSina
thanks
PostPosted: Thu Nov 04, 2010 1:13 pm     Reply with quote
thanks a million , worked on it for 3 days and no result
whats your suggestion ?
thanks again for spending time to help me .
PostPosted: Thu Nov 04, 2010 1:21 pm     Reply with quote
Does it still not work for you ?
If so, remove all external circuits on pin B3. Just look at the pin
with an oscilloscope.
buAliSina
prob exists
PostPosted: Fri Nov 05, 2010 1:46 pm     Reply with quote
I did that way, nothing on oscilloscope.
PostPosted: Fri Nov 05, 2010 2:11 pm     Reply with quote
There may be a hardware problem with your PIC board, or your PIC.
Your programmer may not work.
Try the following simple program that blinks an LED on Pin B0.
Try to make this program work:
#fuses INTRC_IO, NOWDT, PUT, NOLVP
   output_high(PIN_B0);
   output_low(PIN_B0);
Here is a schematic that shows how the LED and series resistor should
be connected to the PIC:
pin      330 ohms      LED
B0  -----/\/\/\/------->|----
                          -----  Ground
buAliSina
Weird
PostPosted: Fri Nov 05, 2010 4:17 pm     Reply with quote
hi,
LED blinked with no error !!! (as i knew it ) ;
Crying or Very sad
PostPosted: Fri Nov 05, 2010 4:25 pm     Reply with quote
Change the program to use pin B3. This is the PWM output pin. See if
you can blink an LED on pin B3. Example:
output_high(PIN_B3);
output_low(PIN_B3);
buAliSina
PostPosted: Fri Nov 05, 2010 4:48 pm     Reply with quote
Confused
Blinked with no problem ;
PostPosted: Fri Nov 05, 2010 4:58 pm     Reply with quote
Try this program. I tested it right now, with vs. 4.084. It worked.
It made the LED light up on pin B3. The oscilloscope shows a 50%
duty cycle squarewave, with a frequency of 244 Hz:
setup_timer_2(T2_DIV_BY_16, 255, 1);
set_pwm1_duty(128);
If this doesn't work, my suggestion is to re-install the CCS compiler.
If that doesn't help, then get a new PIC. Maybe try a different PIC,
such as a 16F877, or something else.
buAliSina
Worked
PostPosted: Fri Nov 05, 2010 5:40 pm     Reply with quote
hi,
Worked ! but whats the dif ?
it was 50% DC ( and i'm not sure about freq )
plz tell me about freq ( i'm tired of calculating ! )
and the dif between our codes r just PUT as you see what do you think ?
PostPosted: Fri Nov 05, 2010 6:11 pm     Reply with quote
The reason I chose the lowest possible frequency for hardware PWM
(244 Hz with a 4 MHz crystal) for my latest example was that I began to
suspect that maybe your board or your equipment has a problem with
frequency response or measuring.
Maybe your oscilloscope doesn't work over 500 Hz ?
