mcataldo
Joined: 04 Jul 2010 Posts: 11 Location: Santiago, Chile
| Help with LCD displaying |
Posted: Sun Oct 31, 2010 1:55 pm |
Hi everyone, I'm working in a power and energy meter what uses a LCD to display these variables and power factor.
I'm having a problem, because I think display routine is right, but in Proteus and in practice LCD doesn't show any character. I'm using LCD library included in CCS.
Please, help me, I attach code and Proteus schematic image.
Thanks.
#include <18F452.h>
#device adc=8
#include <math.h>
#include <lcd.c>
#FUSES XT //LOW speed Osc (<= 4mhz)
#FUSES NOPUT //Power up timer
#FUSES NOBROWNOUT //Reset when Brownout detected
float corriente;
float en_inst;
float energia = 0;
float fp;
float pot_inst[];
float potencia;
float voltaje;
int dt;
int fase;
int i = 0;
int valor1;
int valor2;
short estado = 0;
short flag_1 = 0;
short flag_2 = 0;
#INT_EXT1 // Interrupción de cruce por cero de señal de voltaje
void EXT1_isr()
if(estado == 0)
set_timer0(0);
estado = 1;
#INT_EXT2 // Interrupción de cruce por cero de señal de corriente
void EXT2_isr()
if(estado == 1)
dt = get_timer0(); // Tiempo de desfase entre voltaje y corriente
flag_1 = 1;
estado = 0;
#INT_TIMER1 // Interrupción para muestreo de valores de voltaje y corriente
void muestreo()
set_timer1(64536);
flag_2 = 1;
SET_TRIS_A(0b00011); //Configuración de puertos
SET_TRIS_B(0b00111);
SET_TRIS_D(0x00);
setup_adc_ports(AN0_AN1_AN3);
ext_int_edge(INT_EXT1,L_TO_H);
ext_int_edge(INT_EXT2,L_TO_H);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
set_timer1(64536);
if(flag_1 == 1)
flag_1 = 0;
if(dt <= 10000)
fase = 0.018*dt; // Carga capacitiva
fase = 0.018*(20000-dt); // Carga inductiva
fp = cos(fase); // Cálculo de factor de potencia
if(flag_2 == 1)
i++;
flag_2 = 0;
set_adc_channel(0);
valor1 = read_adc();
delay_us(20);
voltaje = (float)valor1/51; // Valor de voltaje
set_adc_channel(1);
valor2 = read_adc();
delay_us(20);
corriente = (float)valor2/51; // Valor de corriente
pot_inst[i] = voltaje*corriente; // Cálculo de potencia instantánea
if(i == 20)
for (i=1;i<=20;i++)
potencia += 0.05*pot_inst[i]; // Cálculo de potencia RMS
en_inst = potencia/3000; // Cálculo de energía instantánea
energia = energia + en_inst; // Cálculo de energía acumulada
i = 0;
lcd_init(); // Visualización en display de variables
lcd_putc("\f");
lcd_gotoxy(1,1);
printf(lcd_putc,"Pot:%1.1f",potencia);
lcd_putc("W");
printf(lcd_putc,"FP:%1.2f",fp);
lcd_gotoxy(3,2);
printf(lcd_putc,"En:%3.1f",energia);
lcd_putc("Wm");
Posted: Sun Oct 31, 2010 2:51 pm |
This array doesn't have any storage locations allocated to it.
If you want 20 elements in the array, then edit the line above so it
declares the 20 elements.
| Quote: | for (i=1;i<=20;i++)
Arrays start with an index of 0. For an array of 20 elements, the indexes
will go from 0 to 19. Edit the for() statement above so the first index is 0
and so that it checks for "less than" 20 (not less-than or equal to 20).
Then it will go through elements 0 to 19, which is what you need.
| Quote: |
SET_TRIS_D(0x00);
You don't have to set the TRIS. The compiler will do it for you, provided
that you use CCS functions and library routines.
| Quote: | setup_adc_ports(AN0_AN1_AN3);
setup_adc(ADC_CLOCK_INTERNAL); |
The internal A/D clock is not recommended by the PIC data sheet.
Look in the A/D section of the data sheet, in the section on selecting the
A/D clock. It lists the correct clock divisor to use for 4 MHz. Then look
in the 18F452.h file to see the list of constants used by the setup_adc()
routine. Choose the correct constant for your clock divisor.
| Quote: | setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED); |
These two lines are not needed. The PSP and SPI modules are disabled
upon power-on reset of the PIC. You don't need to disable them again.
Also, the setup_spi() line above doesn't disable the SPI port. It actually
enables it. Delete those two lines.
There might be other problems. The major problems are the lack of
declared space for the array, and the for() statement. |
mcataldo
Posted: Mon Nov 01, 2010 11:16 pm |
| Hi, thanks for help. I've made changes you proposed, but I can't get LCD shows something yet; when running simulation on proteus, LCD pins don't show a color (red or blue) indicating 0 or 1, it's like they have no signal. |
Posted: Mon Nov 01, 2010 11:36 pm |
The CCS lcd driver expects the PIC pins to be connected to the LCD pins
as shown below. What does your schematic show ?
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
mcataldo
Posted: Tue Nov 02, 2010 12:14 am |
Ok, I changed pins configuration as you show in lcd.c and it worked so good.
Thank you very much PCM programmer. |
