Taking keyboard input
misel0019
PostPosted: Wed Oct 27, 2010 12:05 am     Reply with quote
I need to take a keyboard input but I can't use getch(); because I wanna start a counter. If counter exceeds it will not wait for the keyboard.
I give you the image of flowchart.
Means the circuit may attach with pc or not. While attach with pc it will wait 5sec to take keyboard input. If input ok then go to main program or wait 5sec and seek for input. If 5sec is over it also goes to main.
Any suggestion.
Regards
Misel
misel0019
flowchart
PostPosted: Wed Oct 27, 2010 12:12 am     Reply with quote
http://yfrog.com/55flowp
flowchart is here
SherpaDoug
PostPosted: Wed Oct 27, 2010 4:31 am     Reply with quote
Use kbhit() to see if a character is coming in. Only if there is a character call getc(), else count time. If you use a software UART you must call kbhit() at least 10 times the serial bit rate to make sure you don't miss the first bit from the keyboard. For a hardware UART you have up to 2 character lengths to catch the character.
misel0019
reply
PostPosted: Wed Oct 27, 2010 10:42 pm     Reply with quote
thanks for the reply
trying to do that
misel0019
PostPosted: Fri Oct 29, 2010 11:28 pm     Reply with quote
thanks SherpaDoug for your suggestion.
misel0019
thanks
PostPosted: Fri Oct 29, 2010 11:29 pm     Reply with quote
thanks it works
