restart_cause() returns MCLR_FROM_RUN but NOMCLR set?
evsource
PostPosted: Fri Oct 29, 2010 4:31 pm     Reply with quote
I've got a 16F88, V4.032 compiler. Chip is resetting in my noisy environment. The restart cause is always MCLR_FROM_RUN, but I have the NOMCLR fuse set. What's going on?
PostPosted: Fri Oct 29, 2010 4:33 pm     Reply with quote
Likely noise on the power pins (Vdd). Possibly on the ground pins (Vss).
