PIC 16F877A LCD with ADC
steppermotor
PostPosted: Thu Oct 28, 2010 7:33 pm     Reply with quote
I'm new to the world of PIC. I've got my LCD working, but I'm trying to display the voltage I that is read in by the PICs ADC port. I'm using the PIC 16F877A, here is sections of my code. However it keeps displaying 8, even when I have it connected to 5 Volts or ground. Any idea what's wrong with my code, that is does not measure the correct voltage.
char print_lcd(char s[])
   lcd_putc('\f');
   delay_ms(250);
   output_high(pin_b0);
   delay_ms(250);
   printf(lcd_putc,"LCD Works");
   delay_ms(5000);
   lcd_gotoxy(0x1,2);
   lcd_putc(s);
   return s;
void measure_voltage()
     char txt[20];
     int16 voltage, adc_value;
      while(true){
      set_adc_channel(0);//set the pic to read from AN0
      delay_us(20)
      adc_value = read_adc();
      voltage = adc_value*(5/1023);
      sprintf(txt, "%i\0", (int)voltage);
      print_lcd(txt);
   char txt[20] = "yes";
   setup_adc(ADC_CLOCK_DIV_8);
   setup_adc_ports(ALL_ANALOG);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   output_low(pin_b0);
   print_lcd(txt);
   measure_voltage();
vinniewryan
PostPosted: Thu Oct 28, 2010 8:19 pm     Reply with quote
Well in the line "voltage = adc_value*(5/1023);", you're multiplying "voltage" by .004, and if your ADC value is anywhere between 1875 and 2124, then your outcome would always be 8 because the PIC would round the number to the nearest integer. Try removing the "(5/1023)" and report the result.
I see no appearent mistakes in your code, so you may also want to post the rest of the code as well.
You can also try writing a simple code that only tests the ADC port, something like:
#include '16f677.h'
#use_delay(clock=xxxxxxx)
#use adc=10
#define//
int16 voltage=0;
      setup_adc(ALL_ANALOG)
      set_adc_channel(0);
      delay_us(20);
      voltage=read_adc;
      printf('%i', voltage);
This is just an example, not a working code.
Vinnie Ryan
steppermotor
Re:LCD W ADC
PostPosted: Thu Oct 28, 2010 8:33 pm     Reply with quote
Thanks, Vinnie for your reply, I made the following modifications. The output is just 000000, even when I have plugged the RA0 to 5 V.
//char txt[20];
int adc_value;
int16 voltage;
//float voltage;
   delay_ms(250);
      set_adc_channel(0);
      delay_us(20);
      voltage=read_adc();
      printf(lcd_putc,"%lu",voltage);
   setup_vref(TRUE);
   output_low(pin_b0);
   //print_lcd(txt);
   measure_voltage();
steppermotor
Got it working
PostPosted: Thu Oct 28, 2010 8:43 pm     Reply with quote
Thanks, but I got it working.
I modified to the following:
      set_adc_channel(0);
      delay_us(20);
      voltage=read_adc();
      printf(lcd_putc,"%u",voltage);
and changed setup_adc(ADC_CLOCK_DIV_32);
from setup_adc(ADC_CLOCK_INTERNAL);
steppermotor
One more problem
PostPosted: Thu Oct 28, 2010 9:12 pm     Reply with quote
When I have a 5V input on my PIC 16F877A ADC AN0 Port is outputs:
1023 on the LCD which I know is the correct value, but when I attempt to multiply by 5/1023 and this does not gives me a result of zero. Perhaps I'm using the wrong int/float/lu. Any suggestions?
int16 voltage;
int16 con_voltage;
float con_voltage2;
//float voltage;
   delay_ms(250);
   //while(1)
      set_adc_channel(0);
      delay_us(20);
      voltage=read_adc();
      printf(lcd_putc,"%lu\n",voltage); // This displays 1023 which is correct for 5 VDC
      con_voltage = (int)voltage * (5/1023);
      printf(lcd_putc,"%lu",con_voltage); //outputs 0
      delay_ms(20);
      con_voltage2 = (int)voltage * (5/1023);
      delay_ms(20);
      printf(lcd_putc,"      %lf",con_voltage2); //outputs 0
steppermotor
Got it again
PostPosted: Thu Oct 28, 2010 9:41 pm     Reply with quote
I changed:
      set_adc_channel(0);
      delay_us(20);
      voltage=read_adc();
      con_voltage2 = voltage * (5.0/1023.0);
      delay_ms(20);
      printf(lcd_putc,"\n%lf",con_voltage2);
