sharat68
Problem with Interfacing PIC 16F877A with LCD |
Posted: Thu Oct 28, 2010 4:36 pm |
I'm trying to display text onto an LCD HD44780 using the PIC 16F877A. I am using the flex_driver given in this forum. I can see the blocks on the LCD and I can adjust the contrast, but I can't get it to display characters or anything on the LCD. Also, I am using PIC C Compiler and MPLAB. Can someone help me?
My PIN Connections:
DB7 - PIN_B7
DB6 - PIN_B6
DB5 - PIN_B5
DB4 - PIN_B4
RS - PIN_B3
RW - PIN_B2
E - PIN_B1 |
The external clock I am using is the FOX F1100E, 20 MHz.
The test code:
#include <16F877A.h>
#include "lcd_16x2.c"
#FUSES HS //Highspeed Osc > 4mhz
#FUSES PUT //Power Up Timer
#use delay(clock = 20000000) // Sets crystal oscillator at 20 megahertz
lcd_init(); // Always call this first.
lcd_putc("\fHello World");
while (TRUE) {
The driver code:
// lcd_16x2.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver. Change these
// pins to fit your own board.
#define LCD_DB4 PIN_B4
#define LCD_DB5 PIN_B5
#define LCD_DB6 PIN_B6
#define LCD_DB7 PIN_B7
#define LCD_E PIN_B1
#define LCD_RS PIN_B3
#define LCD_RW PIN_B2
Flex_lcd driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661 |
Posted: Thu Oct 28, 2010 4:48 pm |
The most likely problems will be:
1. PIC not running. Check this by making an LED blinking program.
See it that works.
2. Incorrect connections between PIC and LCD. Crossed wires, or
wrong pins used, or broken wires, or solder shorts.
3. Using pins B6 and B7 while still having the ICD connected to the board.
Those two pins are used by ICD debuggers and programmers.
Either choose two other pins, or disconnect the ICD from the board.
Make sure you program the board in "Release" mode, and not in "Debug"
mode when you do this. It's easier to just use two other pins than B6 and B7.
4. Other external circuits are attached to the LCD pins, which prevents
the PIC from properly controlling the LCD. |
sharat68
Posted: Thu Oct 28, 2010 6:03 pm |
The PIC is working because I tested it with the LED blinking program and it worked. I'm sure I connected everything correctly and I even switched the B6 and B7 pins to port D. It still doesn't work, I guess I'll try resoldering my LCD. |
