Problem with passing by ref in functions dsPIC30F4012
jventerprises
PostPosted: Tue Oct 26, 2010 12:53 pm     Reply with quote
I am having problems with make32 in versions V4_113 and V4_114. V4_112 and below work fine.
DSPIC30F4012, Windows 7, x64
Specifically I pass a buffer to functions as follows:
main()
    int8 rx_len, buffer[8];
    buffer[0] = 1;
    buffer[2] = 2;
    buffer[3] = 3;
    buffer[4] = 9;
    rx_len = 8;
    process_update_data(buffer, rx_len);
and i process is as follows:
void process_update_data(int8* buffer, int8 rx_len);
    int32 temp32;
       i=0;
       // generate data, upper byte is always 0 (24-bit machine)
       temp32 = make32(buffer[(i + 3)], buffer[(i + 2)], buffer[(i + 1)], buffer[i]);
temp32 should be 0x09030201 but i get 0x01010101
in v4_112 i get 0x09030201.
Any ideas?
Jon
PostPosted: Tue Oct 26, 2010 4:28 pm     Reply with quote
I don't have this compiler, but this looks like the typical CCS problems
with slightly complex expressions (varying between compiler versions).
As a test, create four int8 local variables, a, b, c, d. Load them with the
buffer values. Then run your make32 line on the locals, instead of the
buffer expressions. It may now work.
jventerprises
That does work
PostPosted: Tue Oct 26, 2010 6:27 pm     Reply with quote
Separating the variables works. Thanks for the help.
Jon
PostPosted: Tue Oct 26, 2010 10:41 pm     Reply with quote
File a bug report, wait for V4.115.
