Problem with PIC18F87J50
estenolotien
PostPosted: Tue Oct 26, 2010 5:35 am     Reply with quote
Hi, this is my first message and I don´t know use well this forum, I´m making some personal projects. I choose the pic18f87j50 because is very completed, 2xSPI, 2xUART, USB...
I bougth a board for practice in mikroelectronika and I run a program for switch on some leds and it run ok, but when I run a program for use the uart with RS-232, it no compilate, most of register that I configure manually en my program do not exists in "18f87j50.h", Can you help me? Can you give me the "18f87j50.h" complete?
And, if you have any program that run OK and you want give me, it would be the best.
Thanks,
SherpaDoug
PostPosted: Tue Oct 26, 2010 6:28 am     Reply with quote
Are you using the #use rs232 and printf() or putc() functions of the compiler? You should not have to use any UART registers for basic usage.
estenolotien
PostPosted: Tue Oct 26, 2010 7:30 am     Reply with quote
No, that is my problem, is the first time that I use CCS (recommended for my friend) and I don´t know the main commands. There is any tutorial? or any document with the main functions?
Thanks,
PostPosted: Tue Oct 26, 2010 4:45 pm     Reply with quote
Here is a little CCS tutorial:
http://harfordhackerspace.org/2010/02/programming-pic-microcontrollers-in-c/
Do a Google search for the following search string, and you will find lots
of links to tutorials for CCS. Or the web pages that you get will have the links:
CCS compiler tutorial "#use delay" -ccsinfo.com
Here is the compiler manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
estenolotien
PostPosted: Wed Oct 27, 2010 1:32 am     Reply with quote
Ufff, thanks very much, I've seen it a little and it's very complete. I will read all.
Thanks,
