A/D problem
Bilal
A/D problem
PostPosted: Thu Oct 21, 2010 11:12 pm     Reply with quote
Hi. I am using PIC16F877A. I want to use 2 A/d channels at the same time. One for temp sensor and other for voltage measurements (simple a variable resistor).
The problem is one both are not independent (I guess).
Voltmeter value is changing with temp sensor value.
This is my code
float value;
float volts;
int decic,TC,TF,decif;
float tempc,read,tempf;
setup_port_A( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
do{
set_adc_channel(1);
read = Read_ADC();
tempc=read*1.5;
tempf=(1.8*tempc)+32;
lcd_gotoxy(1,2);
printf(lcd_putc,"Temp %f C",tempc);
set_adc_channel(0);
value = Read_ADC();
volts= value/51;
lcd_gotoxy(1,1);
printf(lcd_putc,"Volts %f",volts);
   } while (TRUE);
Please kindly help me with this problem.
thanks
Wayne_
PostPosted: Fri Oct 22, 2010 1:45 am     Reply with quote
if you look at CCS help it will tell you what is wrong!
You need a 10us delay after switching channels :-
set_adc_channel(2);
delay_us(10);
value = read_adc();
The delay may need tweaking depending on your hardware.
