Weldline1
REGISTRATION FILE ERROR - PCM: The CRG file is damaged |
Posted: Wed Oct 20, 2010 12:02 pm |
Hi everyone,
I have downloaded from microchip web site and installed the
1. HI-TECH C Compiler for PIC10/12/16 MCUs (PRO/Standard/LITE) Update v9.80
and
2. HI-TECH Universal Toolsuite v1.37 (MPLAB IDE Plugin) .
Everything I did in accordance of HI-TECH quickstart guide
When I start the compilation I always get the error window following message: "PCM: The CRG file is damaged"
Do you know anyone where I made a mistake or how can solve this issue?
My MCU is PIC16F877A.
My OP system and MPLAB parameters are the following: MS Vista Home Premium 32-bit,
MPLAB 8.56.00.00 Certified
Windows Vista 6.0.6002.2 Service Pack 2n\a
ICDDB 7.51.00.01 n\a
MasterDB 2.24.17.73 n\a
PCMDB2k 2.22.01.15 n\a
PMFDB4k 2.22.03.00 n\a
DLLInfoRec 8.62.01.0 Certified
DMCI 1.10.0.6 Certified
FieldOrientedControlTI1.00.09.00 Certified
ICD2 8.53.6.1 Certified
KeeloqPlugin 1.0.0.18 Certified
MemGauge 1.00.00.00 Certified
MP32MXSK 1.2.0.0 Certified
MP32SKCBP 1.1.3.0 Certified
MP4KE18E 2.70.00.00 Certified
MP4KE18X 2.60.00.00 Certified
Mp4keDSC 2.60.00.00 Certified
MPAppInOut 1.0.0.0 Certified
MPBootloader 1.0.0.5 Certified
MPChecksum 2.22.02.15 Certified
MPDebugger 3.10.00.00 Certified
MPDevice 2.40.00.00 Certified
MPDiff 1.01.00.00 Certified
MPDisplay2 3.56.00.00 Certified
MPDisplays 3.56.00.00 Certified
MPE12xxx 4.44.00.00 Certified
MPE16xxx 4.62.00.00 Certified
MPE17XXX 4.44.00.00 Certified
MPE18EXX 4.44.00.00 Certified
MPE18HC3 4.44.00.00 Certified
MPE18XXX 4.44.00.00 Certified
MPEditor4 4.56.00.00 Certified
MPEditorStg 1.02.00.00 Certified
MPExpress 2.30.00.00 Certified
MPForum 3.02.00.00 Certified
MPI2KVerify 1.0.0.153 Certified
MPICD3 1.0.3.22 Certified
MPIce2K 4.64.00.00 Certified
MPICE4K 2.64.00.00 Certified
MPIceState 1.22.00.00 Certified
MPIceStopwatch 1.22.00.00 Certified
MPLAB SIM12 2.10.00.00 Certified
MPLAB SIM16 2.10.01.01 Certified
MPLAB SIM18 3.20.00.00 Certified
MPLAB SIM30 4.30.00.00 Certified
MPLAB SIM32 0.00.10.06 Certified
MPLoader 2.22.00.00 Certified
MPLogicDisplay 1.51.00.00 Certified
MPMemory 2.3 Certified
MPPICkit3 1.0.1.29 Certified
MPPm3 2.40.1.45 Certified
MPProgram 2.2 Certified
MPProject 3.6.9 Certified
MPPromate2 8, 0, 0, 3 Certified
MPRealICE 6.0.3.58 Certified
MPRecorder 1.01.00.00 Certified
MPSim 8.62.01.0 Certified
MPSimBreakpoints1.60.0.0 Certified
MPSimulator 1.60.00.2 Certified
MPSKDE 1.00.01.35 Certified
MPSMSK 1.00.01.12 Certified
MPStimulus 2.52.00.00 Certified
MPStopwatch 2.51.00.0 Certified
MPTags 2.00.00.00 Certified
MPTask 1.1.1.0 Certified
MPTranslator 2.31.00.00 Certified
MPUSrcvw4 4.00.01.06 Certified
MPWatchUpdateSupport1.1.2.0 Certified
PICkit 1 2.0.0.3 Certified
PICkit2 0.0.3.63 Certified
Picstart 4.40.0.14 Certified
RTOSTool 1.9.0.6 Certified
SCLStimulus 3.60.00.00 Certified
Suite_CCSPic 2.0.0.7 Uncertified
Suite_dsPIC 3.9.1 Certified
Suite_LSCProxy 2.1.2.0 Certified
Suite_Microchip 3.10.4 Certified
Suite_PIC32 5.1.6 Certified
Vault_CVS 1.2.0.0 Certified
Vault_PVCS 1.0.0.3 Certified
Vault_VSS 1.4.0.2 Certified
Please help me.
Thanks in advance |
Posted: Wed Oct 20, 2010 12:13 pm |
My suspicion is that you have selected CCS in MPLAB as the tool, when
you're trying to use the Hi-Tech compiler.
If you have a problem configuring the Hi-Tech compiler with MPLAB,
ideally you should ask questions on their forum or the Microchip forum. |
Humberto
Posted: Wed Oct 20, 2010 7:30 pm |
This could happen if you tried to Open or Edit the .CRG file.
Regards |
