i2c Problem
zeronix
i2c Problem
PostPosted: Sat Oct 16, 2010 6:48 pm     Reply with quote
Hi Folks.. Smile
I'm working on a project that uses an accelerometer with i2c communication.
The Accelerometer works well with a 1,5meters cable (rs482 multifillar cable).
Recently I bought an 4meter IDC cable to substitute the old one. I can't communicate with accelerometer with the new one!
Any suggestions/tips to increase communication distance on i2c ?
I have tried increase and decrease the pull up resistance and used fast/standard without sauces!
Regards,
José
PostPosted: Sat Oct 16, 2010 9:22 pm     Reply with quote
Use stronger pull-ups (1.6K for a +5v system). Slow down the baud rate.
Try using less than a 50 KHz baud rate. Try using software i2c (no
"Force_hw" parameter in #use i2c).
zeronix
PostPosted: Sat Oct 16, 2010 9:48 pm     Reply with quote
Hi thks for response.
I already try 1k, 2.2k , 8.x k , 20.xk and with 0k :=) with no result!
I will try tomorrow slow down like you said Smile
Where in the #use i2c i change the speed of communication?
My code :
#include <18f2550.h>
#fuses HSPLL,NOWDT,NOBROWNOUT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,MCLR,NOPBADEN,WRTB,CPB
#use delay(clock=48000000)
#define Device_SDA PIN_B0 // Pin defines i2c serial data e serial clock
#define Device_SCL PIN_B1
#use i2c( master,fast, sda=PIN_B0, scl=PIN_B1)  // Configure Device as Master i2c fast mode
Regards,
zeronix
PostPosted: Sun Oct 17, 2010 9:38 pm     Reply with quote
Hi again,
I tried all day to put the i2c cable to work but without success.
I use the parameter that you recommend but without success.
Close the board works perfectly but with my 4m idc cable don't work at all :( (Probably I have to buy a better cable, I didn´t know of that this limitation on cable length in i2c) Smile
I use that code:
#use i2c( master,sda=PIN_B0, scl=PIN_B1,slow, FORCE_HW)
It is possible to slow I2C baudrate giving for example in slow a parameter like slow= 10000?
Sorry to bother you.
Regards,
PostPosted: Sun Oct 17, 2010 10:10 pm     Reply with quote
Use software i2c and slow it down. Example:
#use i2c(master, sda=PIN_B0, scl=PIN_B1, slow=40000)
rnielsen
PostPosted: Mon Oct 18, 2010 8:59 am     Reply with quote
I had a similar problem with a long distance and I needed to abandon using the built in functions and had to bit-bang the I2C bus. It took a bit of work controlling the tris so I didn't get erroneous spikes on the bus but I have one working at 32 feet.
Ronald
bkamen
PostPosted: Mon Oct 18, 2010 9:38 am     Reply with quote
Make sure you have the I2C Specs (if I haven't mentioned it already) -- I have a copy (albeit old, but I think current) here: http://www.benjammin.net/~bkamen/pdf/i2c-specification-v2.1-jan2000.pdf
While there isn't a max length spec, longer cables/lines will lead to changes in transmission characteristics that alter timing -- and that is critical (and mentioned in the PDF).
Cheers,
-Ben
