meloun
Joined: 15 Oct 2010 Posts: 2 Location: CZECH REPUBLIC
MAXQ3181 - cant read voltage, current, temperature correctly |
Posted: Fri Oct 15, 2010 1:35 am |
My SPI communication seems to work perfectly,
chip returns ackknowledges(0xc1, 0xc2), I am able to read STATUS(0x00), all three MODES(0x00), IRQ_FLAG(0x00) and other registers.
But when I am trying to read A.VRMS or B.VRMS or C.VRMS registers, then I'll receive
confused values (0x0, 0xC800, 0x1220091). And also when I'm
changing the input voltage, the values read from these registers
are still the same. I am even not able to read RAWTEMP register correctly (temperature from internal sensor),
so I suppose my problem doesn't depend on wiring diagram or connecting the phases.
I also use just the 8MHz oscillator and 2x15pF capacitors.
Here is my pseudocode.
http://pastebin.com/p2bLWNJn
Fandango
Posted: Fri Oct 15, 2010 1:08 pm |
I saw your pseudo-code, but I have some basic doubts regarding some issues that I would like to discuss with you first.
Reading the datasheet, and besides you said your SPI is ok, I did verify the following:
- SPI clock rate must be less than or equal to 8MHz/4 (so 2MHz), but if running in low power mode or if the crystal is still warming up, the SPI clock frequency must remain at 250kHz or less for proper operation. I am using 72kHz all the time, at least for now regarding testing. What is your SPI frequency?
- The master must also include a communication delay (minimum 50us) following each byte (tx or rx). For frequencies less than 1MHz, increase by a factor of 8 (so 400us minimum). My doubt is: is it necessary to put a delay between a transmission and a reception too? I mean, in your pseudo-code (for example like follow) there is no delay between sending and the first comparing, so the 50ms delay will always be executed. Ok, this is an approach, but what do you thing regarding a finite state machine instead? I think it could be more effective and more easy to debug.
Code: | ////SEND 2.BYTE - LSB portion of address
aux_data = spi_send(0x1C);
if(aux_data == 0xC2){ //maxim ready?
//WAIT FOR DATA
delay_ms(50);
- Since SPI is a full-duplex interface, the master and slave must both transmit the same number of bytes during the command. When a multiple-byte register is read or written (2/4/8 byte length), the least significant byte is read or written first in the command.
Ok, seeing your pseudo-code I did understand the following:
- Is a read operation, because you send 0x28 as first byte. I mean:
0x28 = 0011.1000
--> Bits 7 and 6 are both 0, so = Read
--> Bits 5 and 4 are both 1, so is an 8 bytes data length
--> Bits 3 to 0 are the first byte of address, so is a Virtual Register (0x8..)
- The next byte sent is 0x1C, so the address is 0x81C.
Some considerations here:
1. Is a read operation with 8 bytes data length, but you code shows only the reading of 2 bytes of data. Also, your first comment talking about 4 bytes. Am I wrong?
2. I didn't find any register with this address (0x81C) . Who is the register you want to read (it meaning)?
- Regarding point 1, the datasheet says that "If the master sends fewer bytes than are required by the current command, the MAXQ3181 waits for SPI timeout, then drops the transaction and resets the communication channel." I think must be the same with MAXQ3180. However I think that is ok, no problem here if this happen regarding MAXQ timeout.
- Regarding point 2, the more used virtual registers of the MAXQ3181 are:
Code: | #define AFE_VA 0x831 // RMS Voltage - Phase A
#define AFE_VB 0x832 // RMS Voltage - Phase B
#define AFE_VC 0x834 // RMS Voltage - Phase C
#define AFE_IA 0x841 // RMS Current - Phase A
#define AFE_IB 0x842 // RMS Current - Phase B
#define AFE_IC 0x844 // RMS Current - Phase C
#define AFE_IN 0x840 // RMS Current - Neutral
#define AFE_PF 0x867 // Power Factor - Total
Finally, if you prefer, we can talk through e-mail instead PMs. My e-mail address is daniel.liontec_AT_hotmail.com. I also use Skype (my nick is liontec). I think could be more effective.
Best regards. |
meloun
Posted: Tue Oct 19, 2010 2:05 am |
1/ SPI clock - we use ATMEL MCU with 11.0952MHz crystal and for SPI interface I am using prescaler 64, so 11,0592MHz/64 = 172,800 kHz. Also measured by scope. (CLK signal)
2/ Delay - before any reading, there is delay at least 15ms, it is more than it should be.
3/ Pseudocode -
a/ dataleght - 0x28 => 0010.1000 (not 0011.1000 as you wrote) => 00 -> read, 10 -> 4 bytes(sorry about wrong comments), 1000 -> first portion of address, 0x08[/code]
b/ address - first portion - 0x08, second portion - 0x1C => 0x81C
I want to read A.VRMS and for that I've found this address.
See datasheet page 24
any Idea? |
biozen
Posted: Tue Oct 19, 2010 4:12 am |
meloun wrote: | 1/ SPI clock - we use ATMEL MCU |
Are you using the CCS PIC compiler with Atmel? Are you able to get things moving on the Atmel with a CCS compiled program?!
Locked.
Reason: Atmel is off topic on CCS forum
Meloun & Fandango use Atmel.
No Atmel posts on CCS forum !
-- Forum Moderator
