i2c state problem
amboleos
i2c state problem
PostPosted: Wed Oct 13, 2010 7:57 am     Reply with quote
Hi all,
I have problems with I2C. I need to connect 3 PIC to one master but after six hour, I could only write to one slave. I tried every tutorial and code that I found but in proteus they don't work.
I can see that master passes the info to slave and slave executes
 i2c_write(buffer[address]);
but master reads this value as 0x80 which equal to the state value in that period.
Here is my master code
#include <16F877A.h>
#include "2401.c"
#use i2c(MASTER, SDA=PIN_C4, SCL=PIN_C3)
int8 data=0;
int8 data1=0;
   init_ext_eeprom();    //Call before the other functions are used  ////
   data=read_ext_eeprom(2);  //Read the byte d from the address a     ////
   delay_ms(100);                                                              ////
   write_ext_eeprom(2, 15); // Write the byte d to the address a      ////
   data1 = ext_eeprom_ready();  //Returns TRUE if the eeprom is ready    ////
                            //to receive opcodes                     ////
and slave
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xA0)
BYTE address, buffer[0x10];
BYTE incoming, state;
#INT_SSP
void ssp_interupt ()
   state = i2c_isr_state();
   if(state <= 0x80)                     //Master is sending data
      incoming = i2c_read();
      if(state == 1)                     //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
   if(state == 0x80)                     //Master is requesting data
void main ()
   enable_interrupts(INT_SSP);
   buffer[0]=23;
   buffer[1]=24;
   buffer[2]=25;
   buffer[3]=26;
   buffer[4]=27;
   while (TRUE) {}
PostPosted: Wed Oct 13, 2010 3:23 pm     Reply with quote
This thread has some example code for three i2c slave PICs.
This is a 2-page thread. Read both pages.
http://www.ccsinfo.com/forum/viewtopic.php?t=39242
amboleos
PostPosted: Thu Oct 14, 2010 2:51 am     Reply with quote
Thank you for links, I tried the these codes that are supposed to be working.
Meanwhile my complier is PCWHD 4.112
Master
#include <18f4520.h>
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#define SLAVE1_WRT_ADDR   0x14
#define SLAVE1_READ_ADDR  0x15
#define SLAVE2_WRT_ADDR   0x28
#define SLAVE2_READ_ADDR  0x29
#define SLAVE3_WRT_ADDR   0x42
#define SLAVE3_READ_ADDR  0x43
int8 data1,data2,data3;
  output_high(pin_d4);
   delay_ms(60);
   output_low(pin_d4);
   i2c_start();
   i2c_write(SLAVE1_READ_ADDR);
   data1 = i2c_read(0);
   i2c_stop();
   delay_ms(10);
   i2c_start();
   i2c_write(SLAVE2_READ_ADDR);
   data2 = i2c_read(0);
   i2c_stop();
   delay_ms(10);
   i2c_start();
   i2c_write(SLAVE3_READ_ADDR);
   data3 = i2c_read(0);
   i2c_stop();
   printf(" [ %3U %3U %3U ] \r\n", data1,data2,data3);
   output_high(pin_d6);
   delay_ms(60);
   output_low(pin_d6);
my slave (just one slave is connected to the bus)
#include <18F4520.h>
#device adc=8
#fuses HS,NOWDT,PUT,BROWNOUT,NOLVP
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x14)
int8 adc_result;
#INT_SSP
void ssp_interrupt()
int8 incoming, state;
if(state < 0x80)     // Master is sending data
if(state >= 0x80)   // Master is requesting data from slave
   i2c_write(14);
void main ()
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
adc_result = read_adc();
My results
[14 255 255]
[255 255 255]
[255 255 255]
[255 255 255]
Just the first time, value is correctly readed. Confused
I also tried to clear all other slave codes and just let 1 slave and master communicate, but again it didnt work.
Problem is that slave never enters interrupt again after first one.
PostPosted: Thu Oct 14, 2010 5:39 am     Reply with quote
If this is a simulator (proteus) it may not be your code but the simulator!
I've never trusted any simulator in the 35 years I've been cutting code.
NONE will work 100% properly all of the time.
If real hardware, check the pullups for right values for your speed, board layout, etc.
