PIC16f630 error in interrupt with serial (SOLVED)
Orcino
PostPosted: Tue Oct 12, 2010 11:37 am     Reply with quote
I fogot put #int_TIMER1 in function.
Hi ever body.
In the code below when I enable interrupt TIMER1 the program enters an infinite loop. But it works ok without interruption.
Can anyone help?
Thanks in advance.
#include <16F630.h>
#FUSES NOWDT             // No Watch Dog Timer
#FUSES HS                // High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPROTECT         // Code not protected from reading
#FUSES NOBROWNOUT        // No brownout reset
#FUSES MCLR              // Master Clear pin enabled
#FUSES NOCPD             // No EE protection
#FUSES PUT               // Power Up Timer
#use rs232(baud=9600,parity=N,xmit=PIN_A2,rcv=PIN_C0,bits=8, ERRORS)
#define  RL_TX1 PIN_C3
#define  RL_TX2 PIN_A0
//                              Funções
void acionaRlTX1(void);
void acionaRlTX2(void);
void desligaReles(void);
//                         Variaveis globais
int8 contTempo=0,
     segundos=0;
char x=0;
int1 flagTempoOver=0,
     flagTX1=0,
     flagTX2=0;
void  TIMER1_isr(void)
   contTempo++;
     if(contTempo==10)
       segundos++;
       contTempo=0;
   if(segundos==15)
      flagTempoOver=1;
 setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
 setup_comparator(NC_NC);
 disable_interrupts(INT_TIMER1);
 disable_interrupts(GLOBAL);
        if(kbhit())
          x = getc();
          if (x=='A')
             acionaRlTX1();
             segundos=0;
          if( x=='B')
             acionaRlTX2();
             segundos=0;
     if(flagTempoOver)
         desligaReles();
  if(!flagTX1 && !flagTX2)
     clear_interrupt(int_timer1);
     output_high(RL_TX1);
     flagTX1=1;
    output_high(RL_TX2);
    flagTX2=1;
//           Desliga os reles e reinicia todas as variaveis
  output_low(RL_TX1);
  output_low(RL_TX2);
  flagTX1=0;
  flagTX2=0;
  flagTempoOver=0;
Wayne_
PostPosted: Wed Oct 13, 2010 1:56 am     Reply with quote
You are missing the #INT_TIMER1 directive prior to your routine:-
#INT_TIMER1
Hope this helps.
