Debugging by ICD2
HGHK
Debugging by ICD2
PostPosted: Tue Sep 28, 2010 1:15 am     Reply with quote
My circuit haven't any interface and must debug by icd2 debugger. But by MPLAB IDE I can't debug it. It not work.
My main code is
main.c:
#include "C:\Documents and Settings\HGhK\Desktop\CRP\temp project\main.h"
#include "C:\Documents and Settings\HGhK\Desktop\CRP\temp project\1wire.c"
#include "C:\Documents and Settings\HGhK\Desktop\CRP\temp project\DS1820.c"
#include "C:\Documents and Settings\HGhK\Desktop\CRP\temp project\PCF8583.c"
#ZERO_RAM
// #rom int8 0x1FFF={0x01,0x02,0x03}
#define Time_Period_defult           2
// command set definition
#define Test_Temperature             0x00
#define Read_Temperature_Limits      0x01
#define Set_Temperature_Limits       0x03
#define Read_Time_And_Report         0x07
#define Set_Time_from_Recive         0x0F
#define Read_Sleep_Period            0x1F
#define Set_Sleep_Period             0x3F
#define Reset_Temp_counter           0x7F
#define Controler_Connected          0xFF
#define Report_Temp_counter          0xFE
//  EEPROM Data Address
#define Temperature_In_Reng_Count    0x01
#define Hi_Temperature_Limit         0x04
#define Lo_Temperature_Limit         0x06
#define Period_Time_reg              0x09
date_time_t   Time,*t;
PCF8563_Alarm AlarmTime,*ALT;
float         Temprature;
int8          counter=0,command=0x00,Time_Period=Time_Period_defult;
signed int8   Lo_limit_Temp,Hi_limit_Temp;
// ********** Interrupts Functions ************
#int_SSP
void  SSP_isr(void)
command = getc();
#int_RB
void  RB_isr(void)
command = Controler_Connected;
#int_EXT
void  EXT_isr(void)
command = Test_Temperature;
#include "C:\Documents and Settings\HGhK\Desktop\CRP\temp project\functions.c"
   setup_adc_ports(AN0);
   setup_wdt(WDT_18MS);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_RB);
   enable_interrupts(INT_EXT);ext_int_edge(H_TO_L);
   disable_interrupts(INT_AD);
   disable_interrupts(INT_TBE);
   disable_interrupts(INT_RDA);
   enable_interrupts(INT_SSP);
   disable_interrupts(INT_EEPROM);
config_CLKOUT(PCF8563_CLKOUT_32KHz);
config_PCF8563_Timer(PCF8563_Timer_off);
config_PCF8563_Interrupt(Alarm_Interrupt_Enable,Timer_INT_Pulse_off);
PCF8563_init();
onewire_reset();
Time=&t;
AlarmTime=&ALT;
while (1)
   switch (command) {
    case 0x00:       // Test_Temperature
   disable_interrupts(GLOBAL);
   PCF8563_read_datetime( *t )                             ;
   Temprature    =   ds1820_read()                         ;
   counter       =   read_eeprom(In_Temperature_Reng_Count);
   Lo_limit_Temp =   read_eeprom(Lo_Temperature_Limit)     ;
   Hi_limit_Temp =   read_eeprom(Hi_Temperature_Limit)     ;
   if ((Temprature > Lo_limit_Temp)&(Temprature < Hi_limit_Temp)) {counter++;}
   write_eeprom(In_Temperature_Reng_Count,counter);
   calculate_Alarm_Time();
   Set_Alarm(PCF8563_MHD_Mode,ALT);
   command = 0x00;
    case 0x01:       // Read_Temperature_Limits
        report_Temp_Limits();
        command = 0x00;
    case 0x03:       // Set_Temperature_Limits
        correct_Temp_Limits();
        command = 0x00;
    case 0x07:       // Read_Time_And_Report
        Report_Present_DT();
        command = 0x00;
    case 0x0F:       // Set_Time_from_Recive
        correct_Date_and_Time();
        command = 0x00;
    case 0x1F:       // Read_Sleep_Period
        report_Time_Period();
        command = 0x00;
    case 0x3F:       // Set_Sleep_Period
        correct_Time_Period();
        command = 0x00;
    case 0x7F:       // Reset_Temp_counter
        //reset_Temp_Counter();
        command = 0x00;
    case 0xFF:       // Controler_Connected
        //I_ready();
        command = 0x00;
    case 0xFE:       // Report_Temp_counter
        Temp_count_report();
        command = 0x00;
test(10);
   sleep();
and main.h:
#include <16F876A.h>
#device *=16  ICD=TRUE
#device adc=10
#FUSES WDT                      //Watch Dog Timer
#FUSES LP                       //Low power osc < 200 khz
#FUSES NOPUT                    //No Power Up Timer
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=32768,RESTART_WDT)
#define I2C_SCL   PIN_C3
#define I2C_SDA   PIN_C4
#use rs232(baud=256,parity=O,xmit=PIN_C6,rcv=PIN_C7,bits=8,restart_wdt)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,restart_wdt,force_hw)
and self created driver PCF8563.c:
// PCF8563.C
// Command Set:
// PCF8563_init(void)
// PCF8563_write_byte(int8 address, int8 data)
// PCF8563_read_byte(int8 address)
// bin2bcd(int8 value)
// bcd2bin(char bcd_value)
// PCF8563_set_datetime(date_time_t *dt)
// PCF8563_read_datetime(date_time_t *dt)
// Set_Alarm(int8 AMode,PCF8563_Alarm *AT)
// config_CLKOUT()
// config_PCF8563_Timer()
// config_PCF8563_Interrupt()
#ifndef PCF8563_SDA
#define PCF8563_SDA  PIN_C4
#define PCF8563_SCL  PIN_C3
#endif
#use i2c(master, sda=PCF8563_SDA, scl=PCF8563_SCL)
#ifndef PCF8563_WRITE_ADDRESS
#define PCF8563_WRITE_ADDRESS 0xA2
#define PCF8563_READ_ADDRESS  0xA3
#endif
// Register addresses
#define PCF8563_CTRL_STATUS_REG1   0x00
#define PCF8563_CTRL_STATUS_REG2   0x01
#define PCF8563_SECONDS_REG        0x02
#define PCF8563_MINUTES_REG        0x03
#define PCF8563_HOURS_REG          0x04
#define PCF8563_DAY_REG            0x05
#define PCF8563_WEEK_REG           0x06
#define PCF8563_MONTH_REG          0x07
#define PCF8563_YEAR_REG           0x08
#define PCF8563_ALARM_MINS_REG     0x09
#define PCF8563_ALARM_HOURS_REG    0x0A
#define PCF8563_ALARM_DAY_REG      0x0B
#define PCF8563_ALARM_WEEKDAY_REG  0x0C
#define PCF8563_CTRL_CLKOUT_REG    0x0D
#define PCF8563_CTRL_TIMER_REG     0x0E
#define PCF8563_TIMER_REG          0x0F
// Commands for the Control/Status register.
#define PCF8563_START_COUNTING     0x08
#define PCF8563_STOP_COUNTING      0x28
//*************************************  for Set_Alarm()
#define PCF8563_Alarm_off          0x00
#define PCF8563_M_Mode             0x01
#define PCF8563_MH_Mode            0x04
#define PCF8563_MHW_Mode           0x07
#define PCF8563_MHD_Mode           0x0B
//*************************************  for config_CLKOUT()
#define PCF8563_CLKOUT_off         0x00
#define PCF8563_CLKOUT_32KHz       0x80
#define PCF8563_CLKOUT_1KHz        0x81
#define PCF8563_CLKOUT_32Hz        0x82
#define PCF8563_CLKOUT_1Hz         0x83
//*************************************  for config_PCF8563_Timer()
#define PCF8563_Timer_off          0x00
#define PCF8563_Timer_4KHz         0x80
#define PCF8563_Timer_64Hz         0x81
#define PCF8563_Timer_1Hz          0x82
#define PCF8563_Timer_1_60Hz       0x83
//*************************************  for config_PCF8563_Interrupt()
#define Alarm_Interrupt_Enable     0x01
#define Timer_Interrupt_Enable     0x02
#define A_T_Interrupt_Enable       0x03
#define Timer_INT_Pulse_on         0x10
#define Timer_INT_Pulse_off        0x00
char const weekday_names[7][10] =
{"Sunday"},
{"Monday"},
{"Tuesday"},
{"Wednesday"},
{"Thursday"},
{"Friday"},
{"Saturday"}
// This structure defines the user's date and time data.
// The values are stored as unsigned integers.  The user
// should declare a structure of this type in the application
// program. Then the address of the structure should be
// passed to the PCF8563 read/write functions in this
// driver, whenever you want to talk to the chip.
typedef struct
int8 seconds;    // 0 to 59
int8 minutes;    // 0 to 59
int8 hours;      // 0 to 23  (24-hour time)
int8 day;        // 1 to 31
int8 weekday;    // 0 = Sunday, 1 = Monday, etc.
int8 month;      // 1 to 12
int8 year;       // 00 to 99
}date_time_t;
typedef struct
}PCF8563_Alarm;
int8 LV_sec,C_Mon;
#bit LowVoltage = LV_sec.7
#bit Century = C_Mon.7
void PCF8563_write_byte(int8 address, int8 data)
i2c_start();
i2c_write(PCF8563_WRITE_ADDRESS);
i2c_write(address);
i2c_write(data);
i2c_stop();
int8 PCF8563_read_byte(int8 address)
int8 retval;
i2c_start();
i2c_write(address);
i2c_start();
i2c_write(PCF8563_READ_ADDRESS);
retval = i2c_read(0);
i2c_stop();
return(retval);
//           PCF8563 Initial             //
void PCF8563_init(void)
PCF8563_write_byte(PCF8563_CTRL_STATUS_REG1,PCF8563_START_COUNTING);
// This function converts an 8 bit binary value
// to an 8 bit BCD value.
// The input range must be from 0 to 99.
int8 bin2bcd(int8 value)
char retval;
retval = 0;
   // Get the tens digit by doing multiple subtraction
   // of 10 from the binary value.
   if(value >= 10)
      value -= 10;
      retval += 0x10;
   else // Get the ones digit by adding the remainder.
      retval += value;
return(retval);
// This function converts an 8 bit BCD value to
// an 8 bit binary value.
// The input range must be from 00 to 99.
char bcd2bin(char bcd_value)
char temp;
temp = bcd_value;
// Shifting the upper digit right by 1 is
// the same as multiplying it by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
void PCF8563_set_datetime(date_time_t *dt)
int8 bcd_sec;
int8 bcd_min;
int8 bcd_hrs;
int8 bcd_day;
int8 bcd_mon;
int8 bcd_yer;
int8 wek;
// Convert the input date/time into BCD values
// that are formatted for the PCF8563 registers.
bcd_sec = bin2bcd(dt->seconds);
bcd_min = bin2bcd(dt->minutes);
bcd_hrs = bin2bcd(dt->hours);
bcd_day = bin2bcd(dt->day) | (dt->year << 6);
bcd_mon = bin2bcd(dt->month) | (dt->weekday << 5);
bcd_yer = bin2bcd(dt->year);
wek     = dt->weekday;
// Stop the RTC from counting, before we write to
// the date and time registers.
PCF8563_write_byte(PCF8563_CTRL_STATUS_REG1,PCF8563_STOP_COUNTING);
// Write to the date and time registers.  Disable interrupts
// so they can't disrupt the i2c operations.
i2c_start();
i2c_write(PCF8563_SECONDS_REG);   // Start at seconds reg.
i2c_write(bcd_sec);
i2c_write(bcd_min);
i2c_write(bcd_hrs);
i2c_write(bcd_day);
i2c_write(wek);
i2c_write(bcd_mon);
i2c_write(bcd_yer);
i2c_stop();
// Now allow the PCF8563 to start counting again.
// Read the Date and Time from the hardware registers
// in the PCF8563.   We don't have to disable counting
// during read operations, because according to the data
// sheet, if any of the lower registers (1 to 7) is read,
// all of them are loaded into "capture" registers.
// All further reading within that cycle is done from
// those registers.
void PCF8563_read_datetime(date_time_t *dt)
int8 bcd_sec;
int8 bcd_min;
int8 bcd_hrs;
int8 bcd_day;
int8 wek;
int8 bcd_mon;
int8 bcd_yer;
//  LowVoltage = VL_sec.7
//  Century    = C_Mon.7
// Disable interrupts so the i2c process is not disrupted.
// Read the date/time registers inside the PCF8563.
i2c_start();
i2c_start();
LV_sec  = i2c_read();
bcd_min = i2c_read();
bcd_hrs = i2c_read();
bcd_day = i2c_read();
wek     = i2c_read();
C_Mon   = i2c_read();
bcd_yer = i2c_read(0);
i2c_stop();
// Convert the date/time values from BCD to
// unsigned 8-bit integers.  Unpack the bits
// in the PCF8563 registers where required.
bcd_sec     = LV_sec & 0x7F;
bcd_mon     = C_Mon  & 0x7F;
dt->seconds = bcd2bin(bcd_sec);
dt->minutes = bcd2bin(bcd_min);
dt->hours   = bcd2bin(bcd_hrs & 0x3F);
dt->day     = bcd2bin(bcd_day & 0x3F);
dt->month   = bcd2bin(bcd_mon & 0x1F);
dt->weekday =    wek & 0x07;
dt->year    = bcd2bin(bcd_yer);
void Set_Alarm(int8 AMode)
if (AMode == 0x00)
    i2c_start();
    i2c_write(PCF8563_ALARM_MINS_REG);   // Start at alarm min reg.
    i2c_write(0x80);
    i2c_write(0x80);
    i2c_write(0x80);
    i2c_write(0x80);
    i2c_stop();
void Set_Alarm(int8 AMode,PCF8563_Alarm *AT)
int8 min = 0x80;
int8 hrs = 0x80;
int8 day = 0x80;
int8 wek = 0x80;
switch (AMode){
          case 0x01: min = AT->minutes;
          case 0x04: min = AT->minutes;
                     hrs = AT->hours;
          case 0x07: min = AT->minutes;
                     hrs = AT->hours;
                     wek = AT->weekday;
          case 0x0B: min = AT->minutes;
                     hrs = AT->hours;
                     day = AT->day;
i2c_start();
i2c_write(min);
i2c_write(hrs);
i2c_write(day);
i2c_write(wek);
i2c_stop();
void config_CLKOUT(int8 mode)
PCF8563_write_byte(PCF8563_CTRL_CLKOUT_REG, mode);
void config_PCF8563_Timer(int8 mode)
PCF8563_write_byte(PCF8563_CTRL_TIMER_REG, mode);
void config_PCF8563_Interrupt(int8 mode,ti_tp)
mode = mode | ti_tp;
PCF8563_write_byte(PCF8563_CTRL_STATUS_REG2, mode);
and 1wire.c is:
// (C) copyright 2003 j.d.sandoz / jds-pic !at! losdos.dyndns.org
// released under the GNU GENERAL PUBLIC LICENSE (GPL)
// refer to http://www.gnu.org/licenses/gpl.txt
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
/***********************1Wire Class***********************/
/*Description: This class handles all communication */
/* between the processor and the 1wire */
/* sensors.
/*-------1-wire definitions-------*/
#define ONE_WIRE_PIN PIN_C5
/*******************1-wire communication functions********************/
/************onewire_reset*************************************************/
/*This function initiates the 1wire bus */
/*PARAMETERS: */
/*RETURNS: */
void onewire_reset()  // OK if just using a single permanently connected device
 output_low(ONE_WIRE_PIN);
 delay_us( 500 ); // pull 1-wire low for reset pulse
 output_float(ONE_WIRE_PIN); // float 1-wire high
 delay_us( 500 ); // wait-out remaining initialisation window.
/*********************** onewire_write() ********************************/
/*This function writes a byte to the sensor.*/
/*Parameters: byte - the byte to be written to the 1-wire */
/*Returns: */
void onewire_write(int data)
 int count;
 for (count=0; count<8; ++count)
  delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
  output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
  delay_us( 60 ); // wait until end of write slot.
  output_float(ONE_WIRE_PIN); // set 1-wire high again,
  delay_us( 2 ); // for more than 1us minimum.
/*********************** read1wire() *********************************/
/*This function reads the 8 -bit data via the 1-wire sensor. */
/*Parameters: */
/*Returns: 8-bit (1-byte) data from sensor */
int onewire_read()
 int count, data;
  delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
  output_float(ONE_WIRE_PIN); // now let 1-wire float high,
  delay_us( 8 ); // let device state stabilise,
  shift_right(&data,1,input(ONE_WIRE_PIN)); // and load result.
  delay_us( 120 ); // wait until end of read slot.
 return( data );
and ds1820.c is :
float ds1820_read()
 int8 busy=0, temp1, temp2;
 signed int16 temp3;
 float result;
 onewire_reset();
 onewire_write(0xCC);
 onewire_write(0x44);
 while (busy == 0)
  busy = onewire_read();
 onewire_reset();
 onewire_write(0xBE);
 temp1 = onewire_read();
 temp2 = onewire_read();
 temp3 = make16(temp2, temp1);
 result = (float) temp3 / 2.0;   //Calculation for DS18S20 with 0.5 deg C resolution
// result = (float) temp3 / 16.0;  //Calculation for DS18B20 with 0.1 deg C resolution
 delay_ms(200);
 return(result);
and functions.c is:
// command_out set definition
#define Ready_To_recive              0x00
#define Ready_To_send                0xFF
#define I_Am_Ready                   0x3C
// #define In_Temperature_Reng_Count    0x00
// #define Hi_Temperature_Limit         0x01
// #define Lo_Temperature_Limit         0x03
// #define Period_Time_reg              0x07
void test(unsigned int8 cnt)
for(cnt=cnt;cnt=0;cnt--)
output_high(PIN_A4);
delay_ms( 500 );
output_low(PIN_A4);
delay_ms( 500 );
void calculate_Alarm_Time(Void)
        Time.minutes = Time.minutes + Time_Period;
   for (Time.minutes = Time.minutes ; Time.minutes < 60 ; Time.minutes = Time.minutes - 60 ) {
        Time.hours++;
   for( Time.hours = Time.hours ; Time.hours<24 ;Time.hours = Time.hours - 24 ) {
        Time.day++;
        Time.weekday++;
   for ( Time.weekday = Time.weekday ; Time.weekday < 6 ;Time.weekday = Time.weekday - 6 ) Time.weekday = Time.weekday - 6;
   if (( !Century ) & ( Time.day > 30 )) Time.day = Time.day - 30 ;
   If (( Century  ) & ( Time.day > 31 )) Time.day = Time.day - 31 ;
   AlarmTime.minutes = Time.minutes ;
   Alarmtime.hours   = Time.hours   ;
   Alarmtime.day     = Time.day     ;
   Alarmtime.weekday = Time.weekday ;
void correct_Date_and_Time(void)
putc(Ready_To_recive);
delay_us(50);
Time.seconds = getc();
Time.minutes = getc();
Time.hours   = getc();
Time.day     = getc();
Time.weekday = getc();
Time.month   = getc();
Time.year    = getc();
PCF8563_set_datetime(*t);
void Report_Present_DT(void)
PCF8563_read_datetime( *t );
putc(Ready_To_send);
delay_us(50);
putc(Time.seconds);
putc(Time.minutes);
putc(Time.hours);
putc(Time.day);
putc(Time.weekday);
putc(Time.month);
putc(Time.year);
void report_Temp_Limits(void)
Lo_limit_Temp =  read_eeprom(Lo_Temperature_Limit);
Hi_limit_Temp =  read_eeprom(Hi_Temperature_Limit);
delay_us(50);
putc(Lo_limit_Temp);
Putc(Hi_limit_Temp);
void correct_Temp_Limits(Void)
delay_us(50);
Lo_limit_Temp = getc();
Hi_limit_Temp = getc();
write_eeprom(Lo_Temperature_Limit,Lo_limit_Temp);
write_eeprom(Hi_Temperature_Limit,Hi_limit_Temp);
void report_Time_Period(void)
Time_Period = read_eeprom(Period_Time_reg);
delay_us(50);
putc(Time_Period);
void correct_Time_Period(void)
delay_us(50);
Time_Period = getc();
write_eeprom(Period_Time_reg,Time_Period);
void Temp_count_report(void)
counter = read_eeprom(Temperature_In_Reng_Count);
delay_us(50);
putc(counter);
void I_ready(void)
putc( I_Am_Ready );
void reset_Temperature_Counter(void)
write_eeprom(Temperature_In_Reng_Count,0x0000);
Help me please to debug it.
Douglas Kennedy
PostPosted: Tue Sep 28, 2010 2:56 am     Reply with quote
Well I don't want to debug all this code for you. I suggest you break the code into functional pieces of a dozen lines or more and debug each one. Then assemble the whole program and debug it. It's your code and your responsibility to fix it. If you are stumped then the dozen lines that illustrate your issue will enable others to efficiently spot your issue.
HGHK
ICD2 debuger problem
PostPosted: Tue Oct 05, 2010 2:03 am     Reply with quote
I have problem by ICD2. When I contact it to my circuit it don't any work. I make a debug project and when I run it an error occur and only orange LED twinkle.
