PLL settings of 18F452
theasus
PostPosted: Fri Oct 01, 2010 12:31 am     Reply with quote
Hi, I want to run 18F452 at 40mhz. And I will use 10mhz external crystal by using Pll function. How can I do this?
Thanks.
PostPosted: Fri Oct 01, 2010 2:31 am     Reply with quote
Always, always, always, _tell us your compiler version_...
There are various ways of doing this, on latter compilers.
Old version (should work pretty generically):
#fuses H4
#use delay(clock=40000000)
On newer compilers, you can use
#fuses H4
#use delay(clock=40M)
and on the latest compilers
#use delay(clock=40M, oscillator=10M)
which automatically selects H4 for you.
The old version should still be supported, and is 'safe' with just about any compiler.
