26J11 i2c hw slave and spi master
40inD
PostPosted: Mon Sep 27, 2010 11:06 am     Reply with quote
How to configure 26J11 pic to be an i2c hardware slave and spi master to control SD card and VS1053 at 128kb/s? (i2c-controlled play / record device)
Which pin mapping should be?
PostPosted: Tue Sep 28, 2010 1:52 pm     Reply with quote
Look at the #pin select section in the CCS manual:
bkamen
PostPosted: Wed Sep 29, 2010 9:35 am     Reply with quote
Also make sure to reference the PIC18FxxJ11 family datasheet.
If you don't have it now, you should.
-Ben
