Stuck with LTC1854 ADC Driver
Owais
PostPosted: Thu Sep 23, 2010 4:16 am     Reply with quote
I am trying to interface two LTC1854 12bit ADC devices over SPI bus to a PIC18F8680 device. The constraint here is that SPI must be used in hardware mode (not software bit banging) and SPI mode has to be mode 0 or mode 3. I am using ADCs in single ended acquisition
The ADCs seem to be working fine if configured for SPI mode 3, but for channel 0 only. It seems the ADC device is unable to configure itself for acquisition of other channels. Code returned for +5 input on channel 0 gives 0x7DE0 code, ~= 4.91 V, but still garbage result for other channels.
If configured for mode 0,0 the value returned is not correct at all. For +5 input on channel 0 0x1DE0 code is returned ~= 1.16 V
Can someone help after looking at the LTC1854 datasheet.
//Program to acquire analog data from 2x LTC1854
#include <18F8680.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES MCLR                     //Master Clear pin enabled
#define SPI_MODE_0_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_0_1  (SPI_L_TO_H)
#define SPI_MODE_1_0  (SPI_H_TO_L)
#define SPI_MODE_1_1  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
#define TRISTC  0xf94
#define SSPSTAT 0xfc7
#define SSPCON1 0xfc6
#define SSPCON2 0xfc5
#define ADC1START PIN_E5  //75
#define _ADC1RD   PIN_E6  //74
#define ADC2START PIN_E3  //77
#define _ADC2RD   PIN_E4  //76
//Local Functions
void Initialize_ADCs(void);
void ReadLTC1854_1(int8 channel, unsigned int8* dataoutm, unsigned int8* dataoutl);
void ReadLTC1854_2(int8 channel, unsigned int8* dataoutm, unsigned int8* dataoutl);
unsigned int8 ChannelSelect[8]=
//for single ended acquisition
//SGL  ODD  SELECT1   SELECT0  x  x  NAP  Sleep
0b10000000,//80
0b11000000,//c0
0b10010000,//90
0b11010000,//d0
0b10100000,//a0
0b11100000,//e0
0b10110000,//b0
0b11110000 //f0
   int8 i;
   unsigned int16  adc2smagnitude;//unsigned magnitude
   unsigned int8 adcvaluem,adcvaluel;//conversion result
   int1 adc2ssign;//sign bit
   float adcresult;//floating point value for user printed as string
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_MODE_0_0|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   printf("Testing SPI Port for ADC (LTC1854). Uart setting 9600-8-N-1.\n");
   Initialize_ADCs();
   printf("TRISC = %X\n", *TRISTC);
   printf("SSPSTAT = %X\n", *SSPSTAT);
   printf("SSPCON1 = %X\n", *SSPCON1);
   printf("SSPCON2 = %X\n", *SSPCON2);
   //Acquiring ADC 1 channels
   printf("\nAcquiring ADC 1 channels.\n");
   for(i=0;i<8;i++)
     ReadLTC1854_1(i, &adcvaluem, &adcvaluel);//Using third diagram in figure 7 in datasheet
     adc2smagnitude = (adcvaluem & 0x7F)<<8; //sign not needed
     adc2smagnitude += adcvaluel;
     adc2smagnitude = adc2smagnitude >> 4;//4 unused nibbles for 12 bit device
     adc2ssign = bit_test(adcvaluem,7);
     if(adc2ssign==1)
       adcresult = -5.0f; // span is -5 to +5 volts, MSB = 1 means -5v weight here
       adcresult = 0;
     adcresult += adc2smagnitude*0.00244140625;// magnitude *  10v / 2^12 (12 bit device)
      printf("ADC1-Channel %d, MSB = %X, LSB = %X, Result in Volts = %f\n",i,adcvaluem,adcvaluel,adcresult);
      delay_ms(10);//test to settle adc pins
   delay_ms(400);
   printf("\n");
   //Acquiring ADC 2 channels
   printf("\nAcquiring ADC 2 channels.\n");
   for(i=0;i<8;i++)
     ReadLTC1854_2(i, &adcvaluem, &adcvaluel);
     if(adc2ssign==1)
       adcresult = 0;
      printf("ADC2-Channel %d, MSB = %X, LSB = %X, Result in Volts = %f\n",i,adcvaluem,adcvaluel,adcresult);
   delay_ms(400);
   printf("\n");
  }//while
}//main
output_low(ADC1START);//ADC1 conversion start signal, active high
output_low(ADC2START);//ADC2 conversion start signal, active high
output_high(_ADC1RD);//ADC 1 RD or CS signal, active low
output_high(_ADC2RD);//ADC 2 RD or CS signal, active low
//Read ADC 1
//channel = 0-7
void ReadLTC1854_1(int8 channel, int8* dataoutm, int8* dataoutl)
printf("Sampling Channel Command %X: ", ChannelSelect[channel]);
output_low(_ADC1RD);//enable chip
spi_write(ChannelSelect[channel]);//read command
delay_us(1);//hold
output_high(_ADC1RD);//disable chip
delay_us(5);//hold
output_high(ADC1START);
delay_us(2);//hold
delay_us(2);//wait for conversion
*dataoutm = spi_read(0);
*dataoutl = spi_read(0);
//Read ADC 2
//channel = 0-7
void ReadLTC1854_2(int8 channel, int8* dataoutm, int8* dataoutl)
output_low(_ADC2RD);//enable chip
delay_us(1);//hold
output_high(_ADC2RD);//disable chip
delay_us(5);//hold
output_high(ADC2START);
delay_us(2);//hold
PostPosted: Thu Sep 23, 2010 5:20 pm     Reply with quote
The text description of the SPI communication in the data sheet sounds
like Mode 3 to me, so your experience matches what I read. The data
transfer diagrams don't show mode 3. They don't match the text
description. I don't know what the intention of their tech writers is.
My advice is to cut down your program so it only tests channel 1 (for
example). If possible, get rid of at least 75% of your code. Then I think
it would be simple enough to trouble-shoot.
For an example of cutting it down, get rid of all this:
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
Replace it with this. It uses Mode 3 and it also slows the clock way down.
setup_spi(SPI_MASTER | SPI_MODE_1_1 | SPI_CLK_DIV_16);
There is a lot more code that can be removed (for this test).
Owais
PostPosted: Mon Sep 27, 2010 3:55 am     Reply with quote
I tried the suggestion and reduced code to: (beginning code is same)
  setup_spi(SPI_MASTER | SPI_MODE_1_1 | SPI_CLK_DIV_64);
  output_high(_ADC1RD);//enable chip
   printf("Command word for Channel 1 (single ended) = %X: ", ChannelSelect[1]);
   spi_write(ChannelSelect[1]);//read command
   delay_us(1);//hold
   spi_write(0);//read command, dont care by LTC this byte
   delay_us(5);//hold
   delay_us(2);//hold
   adcvaluem = spi_read(0);
   adcvaluel = spi_read(0);
   if(adc2ssign==1)
     adcresult = -5.0f; // span is -5 to +5 volts, MSB = 1 means -5V weight here
     adcresult = 0;
   printf("MSB = %X, LSB = %X, Result in Volts = %f\n",adcvaluem,adcvaluel,adcresult);
   delay_ms(400);
  }//while
}//main
But still only channel no 0 is sampled and i cant get the ADC to be configured for sampling other channels. I have used two different LTC1854 devices and both shouldn't be damaged. Also the controller (on a small header PCB) is functional as i can drive some serial memories just fine on another board with it.
any other suggestions anyone ?
PostPosted: Mon Sep 27, 2010 4:36 am     Reply with quote
First, I'd encapsulate the 16bit transfers. So something like:
union combiner {
   int8 b[2]
   int16 w;
int16 talk_to_adc(union combiner command) {
   union combiner result;
   //Trigger last configured conversion
   delay_cycles(1);//Only 40nSec required high
   delay_us(5);//wait for conversion - note tconv, is 5uSec worst case
   result.b[1] = spi_read(command.b[1]);
   result.b[0] = spi_read(command.b[0]);
   return result.w;
Then the single command, reads the last configured conversion, and sets the new configuration.
Then your test loop becomes:
  int16 value;
  while(TRUE) {
   value=talk_to_adc(ChannelSelect[1]*256L); //Send 16bit command, get
   //16bit value from last command.
   //Then for testing, don't fiddle around converting to volts, but print
   //the value returned
   printf("%ld",value);
   delay_ms(400);
  }//while
}//main
Then I'd also try channel 2. Given that the 'odd' channels are effectively the -ve inputs in differential mode, it is possible the problem is switching to single ended operation, rather than with retrieving the other channels - worth testing.
I'm using the internal 'cast' abilities of C here, to convert a 16bit value, into a union to access the bytes, then to treat the MSB of this as the sign for output.
