Stepper motor --> whats wrong with this code
W_Schauberg
PostPosted: Sun Sep 26, 2010 8:49 am     Reply with quote
Hi.
I can't run the stepper motor.
If I check voltage before i the ULN driver I get no outputs.
So there must be error in the program but I can't find out what.
This is the link for schematics:
http://tinypic.com/view.php?pic=rkrevn&s=7
There are two micro switches, depending on the position, motor should run forward or backward.
This is the full program:
// motor.h
#include <16F628A.h>
#FUSES INTRC_IO
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
//#FUSES RESERVED               //Used to set the reserved FUSE bits
#use delay(internal=4M)
#include "motor.h"
#define debounce 3            // debounce for mmicroswitch
#define start_delay 150       // delay for motor start in ms
#define speed 0             // higher==slower
#define pause_1 1500       // pause in position 1 in milisecunds
#define pause_2 500        // pause in position 2 in milisecunds
#define FOUR_PHASE TRUE    // number of windings in the motor
                           // TRUE - 4
                           // FALSE - 2
#define direction 1        // CV0
                           // CCV
#ifdef FOUR_PHASE
BYTE const POSITIONS[4] = {0b0101,
                           0b1001,
                           0b1010,
                           0b0110};
#else
BYTE const POSITIONS[8] = {0b0101,
                           0b0001,
                           0b1001,
                           0b1000,
                           0b1010,
                           0b0010,
                           0b0110,
                           0b0100};
#endif
unsigned char my_flags = 0;
// 0 - detection on input 1 (pin A 0) - stop in forward
// 1 - detection on input 1 (pin A 1) - stop in backward
// 2 - motor is running
unsigned char debounce_timer = 0;
unsigned long motor_pause = 0;
#int_RTCC
void  RTCC_isr(void) // timer0 interrupt each 1 ms.
   unsigned char tmp;
   if (motor_pause--);
   tmp = (~input_a()) & 0x03;    // port status send to tmp
   if (debounce_timer)          // is timer activated
      debounce_timer--;
      switch (tmp)
         case 0x01 : // detected input 1
                     if (my_flags & 0x01)
                        my_flags &= 0xFA;       // debaunce OK,stop the motor, delete flag
                        motor_pause = pause_1;    // set pause 1
                        my_flags = 0x01;        // debaunce started,set flag
                        debounce_timer = debounce;
         case 0x02 : // detected input 2
                     if (my_flags & 0x02)
                        my_flags &= 0xF9;
                        motor_pause = pause_2;
                        my_flags = 0x01;
         case 0x00 : my_flags &= 0xFC; // kill all flags
         default   : my_flags &= 0xF8; // error, stop the motor
void drive_stepper(void)
   static BYTE stepper_state = 0;
   BYTE i;
   while (my_flags & 0x04)
      //delay_ms(speed); // for max speed
      output_b (POSITIONS[ stepper_state ]);
      if(direction) // if forward
         stepper_state=(stepper_state+1)&(sizeof(POSITIONS)-1);
         stepper_state=(stepper_state-1)&(sizeof(POSITIONS)-1);
   set_tris_a(0x0F); // PORTA 0 - 3 inputs for triggers
   set_tris_b(0x00); // PORTB 0 - 3 inputs for motor.
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_RTCC);
   for(;;)
      if (!(my_flags & 0x04)) // if the motor is stopped
         if(!motor_pause) // if the pause if over
            debounce_timer = start_delay; // run delay to ignore inputs on motor start
            drive_stepper(); // run motor
PostPosted: Sun Sep 26, 2010 10:00 am     Reply with quote
Obvious first thing, you have 'MCLR' enabled, but nothing pulling the MCLR pin high in the schematic. The PIC won't run....
Fix this, and you should then see something. You'll probably have to add the delay back in the motor drive loop, or the pulses will be much too fast for the motor.
W_Schauberg
PostPosted: Wed Sep 29, 2010 12:32 am     Reply with quote
I removed the MCLR from the code, but I still can't get no outputs.
I can add some LED's and set some other outputs ?
PostPosted: Wed Sep 29, 2010 1:49 am     Reply with quote
Removing MCLR, still leaves it enabled. It is the default setting. You need to have 'NOMCLR', or add the pull-up to the pin.
Also, you need the delay in the driver loop. Fastest that most steppers can 'start' with simple drives like this is probably around 500Hz to 1KHz, if only lightly loaded. So you need some delay in this loop as it is currently used (delay_ms(1) will probably work).
