USB CDC problem with CPUDIV
denis_11
PostPosted: Tue Sep 21, 2010 4:22 pm     Reply with quote
Hi I'm trying a PIC 18f14k50 with usb-cdc emulating a serial com, I use a real crystal of 20MHz but unfortunately when I connect the circuit to the pc tells me that it did not work properly ... I'm sure I have some problem with the crystal and its setting ... I also connected capacitor 470nF and the circuit is ok ... these are the fuses:
#include <18F14k50.h>
#device adc=8
#FUSES HS
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOBROWNOUT               //No browno BORV19
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOMCLR                     //Master Clear pin disabled
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOWRTB                   //Boot block not write protected
#FUSES HFOFST
#FUSES NOWRT0
#FUSES NOWRT1
#FUSES USBDIV1
#FUSES BBSIZ2K                  //2K words Boot Block size
#FUSES CPUDIV3
#FUSES PLLEN
#FUSES PCLKEN
What's wrong?
PostPosted: Tue Sep 21, 2010 4:47 pm     Reply with quote
The 18F14K50 data sheet doesn't show a 20 MHz crystal to be an option
for USB. It must be a 6 MHz or 12 MHz crystal. Look at these tables
in the PIC data sheet:
TABLE 2-4: LOW SPEED USB CLOCK SETTINGS
TABLE 2-5: FULL-SPEED USB CLOCK SETTINGS
Besides those crystals, there are some other options for an external
oscillator, as shown in the tables given above.
Also, you can't use the internal oscillator. The data sheet says:
2.11 USB Operation
Because of timing requirements imposed by the USB
specifications, the Primary External Oscillator is
required for the USB module.
If you want more crystal options for USB, you need to use a PIC that
allows them, such as the 18F4550.
