Problem: Writing\Reading to\from internal EEPROM
HGHK
PostPosted: Tue Sep 21, 2010 3:30 pm     Reply with quote
I don't know about EEPROM writing. What is the allowable Address range for writing data. I need a example about it. Help me please.
I use PIC16F876a
PostPosted: Tue Sep 21, 2010 4:11 pm     Reply with quote
What is the allowable Address range for writing data ?
Always post your PIC. We don't remember it from your previous posts.
Look in the front of the data sheet for your PIC. It will list the number
of bytes of data eeprom that are available. For example: 256
The address range is then 0 to 255.
http://www.ccsinfo.com/forum/viewtopic.php?t=43338&start=3
HGHK
#rom
PostPosted: Wed Sep 22, 2010 6:08 am     Reply with quote
what is doing of :
#rom int8 0xf00000={0x55, 0xAA}
in your program?
pleas explain that 0x55 , 0xaa, 0xf00000 are refer to what?
PostPosted: Wed Sep 22, 2010 2:13 pm     Reply with quote
It's a method to pre-load the data eeprom when the PIC is programmed
with your ICD2 (etc.) programmer. So when the PIC first starts running
it will already have eeprom address 0 set to 0x55, and eeprom address 1
will be set to 0xAA. The eeprom address in Flash Memory is found in the
Programming Specification for your PIC. However, see below:
The new method (recommended by several forum members) is to let
the CCS compiler supply the Flash Memory address of the data eeprom.
That way, you don't have to find it in the Programming Specification.
You can do this with the "getenv()" function, as shown below:
#include <16F877.H>
#ROM getenv("EEPROM_ADDRESS") = {0x55, 0xAA}
By using this method, you can more easily switch your program to a new
PIC family, such as from 16F to 18F.
HGHK
write eeprom
PostPosted: Tue Sep 28, 2010 1:03 am     Reply with quote
Only by using write_eeprom without #ROM address={list} I write in eeprom data in PIC16F876A and it not work carefully.
Help me please.
PostPosted: Tue Sep 28, 2010 1:15 pm     Reply with quote
See this demo program:
http://www.ccsinfo.com/forum/viewtopic.php?t=17590&start=1
rikotech8
PostPosted: Thu Oct 11, 2012 10:47 am     Reply with quote
What is the first compiler version that support
Mine is 4.114.
PostPosted: Thu Oct 11, 2012 11:38 am     Reply with quote
Please don't ask eeprom questions all over the forum.
This is your eeprom thread, here:
http://www.ccsinfo.com/forum/viewtopic.php?t=48909
Let's continue working on your eeprom questions there.
Ask your questions in that thread.
