pic 16f877a and 10 adc ci ad7490 ,it's possible?
magnoedu
PostPosted: Sun Sep 19, 2010 1:32 am     Reply with quote
Hello friends
I'm trying to do a project for a data logger with a PIC 16F877A and ten ad7490 cis of sixteen entries, working with protocol spi.
wanted to know if is possible?
if anyone has any similar project or could help me develop the code?
PostPosted: Mon Sep 20, 2010 5:21 am     Reply with quote
It should be possible.
Start with just ONE of the AD7490s and write the SPI code that you need.
Have a simple 1 to 16 loop to read and print the raw adc result.
Then, when that works, add a second AD7490,edit code to address it and verify that works.
A simple outside loop of incrementing the SPI address of the 7490s with an inside loop of addressing the 16 channnels per ADC is where I'd begin.
With a simple print the raw adc result to a PC.
The idea is to start simple,working code, and build upon that.
Keep the original code, and edit a 2nd,3rd,4th,...copy as you go, that way you can always go back to a version that worked!
Also make lots of comments as to what you're doing!
Hope this helps.
Jay
magnoedu
thanks
PostPosted: Mon Sep 20, 2010 7:26 pm     Reply with quote
I start this project, I work how you tell me.
I post here if possible.
thanks
Emerson
