Multiple files compilation
christian.koji
PostPosted: Tue Sep 14, 2010 5:27 am     Reply with quote
Hey guys I'm with a problem. I'd like to compile multiple files using one file to declare variables and make #defines. The problem is: if I have a
main.c
#include <variable.c>
#include <defines.c>
#include <functions.c>
main(){
   sum();
variable.c
int a,b,c;
defines.c
#define max 10
#define min  0
functions.c
int sum(){
   c = a+b;
When I compile it generates an error, it says that the variables a, b and c are not defined. I'd like to know how do I compile these files in ccs without using extern and still use the variables as globals.
PostPosted: Tue Sep 14, 2010 6:58 am     Reply with quote
Are you working in CCS directly, or using MPLAB?.
What you describe is totally correct, and will work. _However_ if you are working in MPLAB, it is _vital_ that only the 'main' file is in MPLAB's file inclusion list. Otherwise it tries to load an compile the 'include' files 'on their own', and will give errors such as you are describing.
It'd be 'normal practice' to use '.h' extensions for the include files, rather than .c. to make it clear that that these are not 'stand alone'. CCS is a little 'naughty' in their own examples in this regard....
christian.koji
PostPosted: Thu Sep 16, 2010 10:23 am     Reply with quote
I'm using CCS directly, but it generates the error =/.
I tried to use .h extension also but get the same errors.
Is there some project configuration I have to do to deal with multiple files?
PostPosted: Thu Sep 16, 2010 2:39 pm     Reply with quote
Show the header (the part above including variable.c).
You would again get this as an error, if there was a function definition here, without a closing brace. You also need the processor define, and fuses, before anything else.
