Microware 93S46 driver
rafaluc
PostPosted: Mon Sep 06, 2010 2:21 pm     Reply with quote
What does for the driver need below to write a 93S46?
Would anybody help please?
#ifndef EEPROM_SELECT
#define EEPROM_SELECT PIN_B0
#define EEPROM_CLK    PIN_B1
#define EEPROM_DI     PIN_B2
#define EEPROM_DO     PIN_B3
#define EEPROM_VSS    PIN_B4
#define EEPROM_W      PIN_B5
#define EEPROM_PRE    PIN_B6
#define EEPROM_VDD    PIN_B7
#define EEPROM_ADDRESS BYTE
#define EEPROM_SIZE    64
void init_ext_eeprom() { //93S46 16 BITS
   byte cmd[2];
   byte i;
   cmd[0]=0x80;
   cmd[1]=0x9;
   for(i=1;i<=4;++i){
      shift_left(cmd,2,0);
   output_high(EEPROM_SELECT);
   for(i=1;i<=10;++i) {
      output_bit(EEPROM_DI, shift_left(cmd,2,0));
      output_high(EEPROM_CLK);
      output_low(EEPROM_CLK);
   output_low(EEPROM_DI);
   output_low(EEPROM_SELECT);
void write_ext_eeprom(EEPROM_ADDRESS address, long int data) { //93S46 X 16 BITS
   byte cmd[4];
   byte i;
   cmd[0]=0;
   cmd[1]=0;
   cmd[2]=0;
   cmd[3]=0;
BIT_SET(cmd[3],7);
BIT_SET(cmd[3],5);
if(bit_test(address,5))BIT_SET(cmd[3],4);
if(bit_test(address,4))BIT_SET(cmd[3],3);
if(bit_test(address,3))BIT_SET(cmd[3],2);
if(bit_test(address,2))BIT_SET(cmd[3],1);
if(bit_test(address,1))BIT_SET(cmd[3],0);
if(bit_test(address,0))BIT_SET(cmd[2],7);
if(bit_test(data,15))BIT_SET(cmd[2],6);
if(bit_test(data,14))BIT_SET(cmd[2],5);
if(bit_test(data,13))BIT_SET(cmd[2],4);
if(bit_test(data,12))BIT_SET(cmd[2],3);
if(bit_test(data,11))BIT_SET(cmd[2],2);
if(bit_test(data,10))BIT_SET(cmd[2],1);
if(bit_test(data,9))BIT_SET(cmd[2],0);
if(bit_test(data,8))BIT_SET(cmd[1],7);
if(bit_test(data,7))BIT_SET(cmd[1],6);
if(bit_test(data,6))BIT_SET(cmd[1],5);
if(bit_test(data,5))BIT_SET(cmd[1],4);
if(bit_test(data,4))BIT_SET(cmd[1],3);
if(bit_test(data,3))BIT_SET(cmd[1],2);
if(bit_test(data,2))BIT_SET(cmd[1],1);
if(bit_test(data,1))BIT_SET(cmd[1],0);
if(bit_test(data,0))BIT_SET(cmd[0],7);
   for(i=1;i<=25;++i)
      output_bit(EEPROM_DI, shift_left(cmd,4,0));
   delay_ms(1);
 delay_ms(11);
rafaluc
PostPosted: Thu Sep 09, 2010 6:28 pm     Reply with quote
How to do to write in eeprom 93S46?
some idea, please help!!!!!
PostPosted: Thu Sep 09, 2010 7:20 pm     Reply with quote
Can you post a link to the data sheet and/or manufacturer?
When I search on "Microware 93S46" there are no hits. The only hit that seems to match is the M93S46 of ST Microelectronics but that is too far off from your description to spend time on.
rafaluc
PostPosted: Fri Oct 01, 2010 6:55 am     Reply with quote
the driver that I ordered belongs to the 93c46 and me need of the 93S46 or 93CS46
try: http://www.pjrc.com/tech/8051/93CS46.pdf
PostPosted: Fri Oct 01, 2010 7:32 am     Reply with quote
The drivers should be the same.
Both devices use the same Microwire protocol, same commands, same size and block layout.
rafaluc
rafaluc
PostPosted: Mon Oct 04, 2010 5:22 am     Reply with quote
Then, the difference is that to 93S has the protected area!!!
How to modify the driver of the 93C46 to write in the protected area?
