HTRC110 and PIC
denis_11
HTRC110 and PIC
PostPosted: Sat Sep 04, 2010 7:14 am     Reply with quote
Hi I am working with a pic 16F876 and HTRC110. I would like to know how to initialize communication between these two components. I have already created a routine I2C with CLOCK DIN and DOUT but I wanted to know if I could also use the SPI. I would also like to know where I can find an example of a sequence of read / write so I understand how I set the functions of the pic. Thanks to all.
dyeatman
PostPosted: Sat Sep 04, 2010 10:00 am     Reply with quote
The data sheet is here:
www.nxp.com/documents/data_sheet/ht037030.pdf
I think it would be a good idea for you to read it and your questions about
how it should be initialized will be answered. Otherwise one of us would
have to read it for you and tell you what it says which is not the best way,
you need to learn the information for yourself.
Here is a detailed explanation on how to communicate with it and how it
works. It also references a driver in C18 you can use as a template to write
your own.
http://www.embedded-code.com/source-code/rfid/125khz-rfid-readers/htrc110-em4102-rfid-reader-driver
Google and Forum Search are some of your best tools!!!!
denis_11
PostPosted: Sat Sep 04, 2010 6:17 pm     Reply with quote
ok thank you, I read the datasheet and I realized that I can use the libraries of i2c because I can join together data-in and data-out. I realized that should I send the byte 0xC0 for write tag and then send all other bytes and then stop, or use WRITE_TAG_N that I still have not figured out how to act ... to read the tags I send 0xE0 and wait to receive data ... right? This is what I did not understand. Then you think I can use the i2c simple? ie: START, WRITE_BYTE, WRITE_BYTE ,.... , STOP;
PostPosted: Sat Sep 04, 2010 6:58 pm     Reply with quote
http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus#3-Wire_Serial_Buses
http://en.wikipedia.org/wiki/I%C2%B2C
denis_11
PostPosted: Sat Sep 04, 2010 7:14 pm     Reply with quote
I do not understand why you wrote me those links ... I know how works the I2C and SPI, but I wanted clarity because the I2C is the start, controlbyte, bytes, bytes ....., stop over 2 lines and the SPI have 3 lines and not controlbyte start and stop... I wrote a routine to handle the i2c on 3lines,sdain , sdaout and clk ... Now I haven't a HTRC110 and for this I asked some clarification from the datasheet that it is not clear if it uses the SPI or I2C ... I realized that is a I2C modified but wanted to know if I could use the same libraries or what of i2c change ... not sending the controlbyte so I suppose it was enough the start and then send the bytes and then stop ... right?
PostPosted: Sat Sep 04, 2010 10:02 pm     Reply with quote
8.7. Serial Interface
The communication between the HTRC110 and the microcontroller is done
via a three wire digital interface. The interface is operated by the
following signals:
SCLK Clock
DIN Data Input
DOUT Data Output
The signals list above are not for i2c.
The Philips documentation is not very complete.
This appnote describes a 2-wire SPI interface for another chip.
It provides a better description:
http://micromegacorp.com/downloads/documentation/AN007-SPI%20Interface.pdf
SPI Interface
The uM-FPU can be connected using either a 2-wire or 3-wire SPI
interface depending on the capabilities of the microcontroller. The 3-wire
SPI interface uses separate data input and data output pins on the
microcontroller, while the 2-wire SPI interface uses a single bidirectional
pin for both data input and data output.
Geps
PostPosted: Mon Sep 06, 2010 7:46 am     Reply with quote
As PCM Programmer says the device uses SPI.
I've used it before but unfornuately NDA and IP clauses prevent me from releasing my code.
The HTRC110 requires an intialisation pulse BEFORE you transit any data and every time you send it a command. From memory you take the clock line high, followed by the data_in line and then low the clock.
It is explained in the datasheet.
You also don't want to write 0xE0 to read_tag. You need 3 1s without the trailing 0s.
koray_duran
PostPosted: Sun Nov 14, 2010 10:45 am     Reply with quote
Hi Denis!
if you writed a driver for htrc110, please share with us.
MKY
Here is Htrc110 fully working code
PostPosted: Sat Apr 25, 2015 11:56 am     Reply with quote
#include <16F721.h>
#device adc=8
#FUSES   INTRC_IO, PLLEN, BROWNOUT, NOWDT, PUT, PROTECT, NOBROWNOUT, WRT
// Htrc110 Kristal 4MHz
#use    delay(clock=16000000)
#use   rs232(baud=4800, ERRORS, parity=N, xmit=PIN_B7, rcv=PIN_B5, bits=8, STREAM=PORT1)
#OPT 8
#ZERO_RAM
#define   BOYUT_DIZI_PORT1_GELEN   40
#define   BOYUT_DIZI_PORT1_GIDEN   40
#define   KISA         0
#define   UZUN         1
#BYTE   Timer0      = 0X01
#BYTE   PORTA      = 0X05
#BYTE   PORTB      = 0X06
#BYTE   PORTC      = 0X07
#BYTE   OPTION      = 0X81
#BYTE   WPUA      = 0X95
#BYTE   IOCA      = 0X96
#BYTE   IOCB      = 0X116
#BYTE   TXREG      = 0X19
#BYTE   OSCCON      = 0X90
#BIT   PinRunLed   = PORTC.1
#BIT   PinKartLed   = PORTC.2
#BIT   SpiSclk   = PORTB.6
#BIT   SpiMosi   = PORTC.7
#BIT   SpiMiso   = PORTB.4
#BYTE   Timer1Ust   = 0X0F
#BYTE   Timer1Alt   = 0X0E
int   CevirAscii(int);
int   ChkSumDizi(int);
int   Ascii2Hex(int);
void   ChkSumHesapla(char *p);
int   ChkSumKontrol(char *p);
int   IdKontrol(char *p);
void   Port1Tamam(void);
void   DiziDataYerlestir(void);
void   Htrc110Init(void);
char   Htrc110ReadTag(char);
void   Htrc110ReadSet(void);
char   SpiDataGonder(char);
void   Gecikme(void);
void   DiziYerlestir(int);
char   DiziPort1Gelen[BOYUT_DIZI_PORT1_GELEN];
char   DiziPort1Giden[BOYUT_DIZI_PORT1_GIDEN];
int   DiziRfidGelen[12];
char   DiziOkunanEtiket[5];
char   DiziOkunanEtiketOnceki[5];
char   DiziRfidOkunan[5];
int   DurumBaslangic;
int   SayacRunLed;
int   E2CihazNo=5;
int   SayacPort1Gelen;
int   SayacPort1Giden;
char   KarakterRs232;
int   SayacRfidGelen;
int   TamponTimer;
int   Bayrak;
int   Sayac;
int   SayacKose;
int16   SayacEtiketSifirlama;
#BIT   PinData      = Bayrak.0
#BIT   Sinyal      = Bayrak.2
#int_TIMER1
void   Timer1KesmeGeldi(void){
   if(++SayacRunLed > 64){
      PinRunLed=1;
      SayacRunLed=0;
   else{
      PinRunLed=0;
   if(PinKartLed!=0){
      if(++SayacEtiketSifirlama>150){
         SayacEtiketSifirlama=0;
         PinKartLed=0;
         DiziOkunanEtiket[0]=0;
         DiziOkunanEtiket[1]=0;
         DiziOkunanEtiket[2]=0;
         DiziOkunanEtiket[3]=0;
         DiziOkunanEtiket[4]=0;
         DiziRfidOkunan[0]=0;
         DiziRfidOkunan[1]=0;
         DiziRfidOkunan[2]=0;
         DiziRfidOkunan[3]=0;
         DiziRfidOkunan[4]=0;
         DiziOkunanEtiketOnceki[0] =0;
         DiziOkunanEtiketOnceki[1] =0;
         DiziOkunanEtiketOnceki[2] =0;
         DiziOkunanEtiketOnceki[3] =0;
         DiziOkunanEtiketOnceki[4] =0;
         sprintf(DiziPort1Giden, "\X02%02uKY\X05", E2CihazNo);                  // Kart Yok
         ChkSumHesapla(DiziPort1Giden);
         SayacPort1Giden=0;
         enable_interrupts(INT_TBE);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);                              //16 ms
   restart_wdt();
#int_TBE
void   SeriPort1DataGittiInterrupt(void){
   KarakterRs232 = DiziPort1Giden[SayacPort1Giden];
   if((++SayacPort1Giden > BOYUT_DIZI_PORT1_GIDEN) || (KarakterRs232 == 0) ){
      disable_interrupts(INT_TBE);
   else{
      fputc(KarakterRs232, PORT1);
#int_RDA
void   SeriPort1DataGeldiInterrupt(){                                //
   KarakterRs232 = fgetc(PORT1);
   if     (KarakterRs232==2 || SayacPort1Gelen >=BOYUT_DIZI_PORT1_GELEN ){
      SayacPort1Gelen=0;
   else if(KarakterRs232==3 && DiziPort1Gelen[0]==2){
      if(ChkSumKontrol(DiziPort1Gelen)==1){
         if(IdKontrol(DiziPort1Gelen)==1){
            if(   DiziPort1Gelen[3]=='R'){
               if(DiziPort1Gelen[4]=='S'){                     // Reset Cpu
                  reset_cpu();
               else if(DiziPort1Gelen[4]=='O'){
                  for(Sayac=0 ;Sayac<255; Sayac++){
                     fprintf(PORT1, "*[%2X] = %2X      ", Sayac, *Sayac);
               else if(DiziPort1Gelen[4]=='A'){   // Raeder Aç
                  Htrc110ReadTag(0XE0);
               else if(DiziPort1Gelen[4]=='K'){   // Reader Kapat
                  Htrc110ReadTag(0X00);
            else if(DiziPort1Gelen[3]=='S'){
               if(DiziPort1Gelen[4]=='R'){                     // Reset Cpu
                  reset_cpu();
            else if(DiziPort1Gelen[3]=='I'){
               if(DiziPort1Gelen[4]=='O'){                     // Id Numarası
            else if(DiziPort1Gelen[3]=='C'){
               if(DiziPort1Gelen[4]=='I'){                     // Cihaz Initialize
                  Htrc110Init();
            else if(DiziPort1Gelen[3]=='P'){
               if(DiziPort1Gelen[4]=='O'){                     // Parametre Oku
                  Htrc110ReadSet();
            else if(DiziPort1Gelen[3]=='K'){                     // Kart Oku
                  if(PinKartLed==1){
                     sprintf(DiziPort1Giden, "\X02%02uKN%2X%2X%2X%2X%2X\X05", E2CihazNo, DiziRfidOkunan[0],  DiziRfidOkunan[1],  DiziRfidOkunan[2],  DiziRfidOkunan[3],  DiziRfidOkunan[4] );
                  else{
                  SayacPort1Giden=0;
   DiziPort1Gelen[SayacPort1Gelen++] = KarakterRs232;
#int_RAB
void   PortABDegistiInterrupt(void){
   TamponTimer=Timer0;
   if(SpiMiso==0)   PinData=0;
   else      PinData=1;
   Timer0=0;
   if(   TamponTimer>8 && TamponTimer<21){
      Sinyal=KISA;
   else if(TamponTimer>20 && TamponTimer<40){
      Sinyal=UZUN;
   else{
      DurumBaslangic=0;
      SayacRfidGelen=0;
   if(   DurumBaslangic==0){
      if(Sinyal==UZUN && PinData==1){
         DurumBaslangic=10;
         SayacRfidGelen=0;
   else if(DurumBaslangic==10){
      if(Sinyal==KISA ){
         if(++SayacRfidGelen==16){   // Başlangıç Oluştu
            DurumBaslangic=20;
            SayacRfidGelen=0;
            SayacKose=0;
      else{
         DurumBaslangic=0;
   else if(DurumBaslangic==20){
      if(Sinyal==UZUN){
         if(PinData==0){
            DiziYerlestir(1);
         else{
            DiziYerlestir(0);
         SayacKose=0;
      else if(Sinyal==KISA){
         if(++SayacKose==2){
            SayacKose=0;
            if(PinData==0){
               DiziYerlestir(1);
            else{
               DiziYerlestir(0);
            return;
      else{
         SayacRfidGelen=0;
         DurumBaslangic=20;
void   DiziYerlestir(int GelenData){
   int   Bolum;
   int   Mod;
   Bolum=SayacRfidGelen/5;
   Mod = (Bolum*5+7) - SayacRfidGelen;
   if(GelenData==1){
      bit_clear(DiziRfidGelen[Bolum], Mod);
   else{
      bit_set(DiziRfidGelen[Bolum], Mod);
   if(++SayacRfidGelen>54){
      if((DiziRfidGelen[0]%2==0)&&(DiziRfidGelen[1]%2==0)&&(DiziRfidGelen[2]%2==0)&&(DiziRfidGelen[3]%2==0)&&(DiziRfidGelen[4]%2==0)&&(DiziRfidGelen[5]%2==0)&&(DiziRfidGelen[6]%2==0)&&(DiziRfidGelen[7]%2==0)&&(DiziRfidGelen[8]%2==0)&&(DiziRfidGelen[9]%2==0)){
         DiziRfidGelen[0] &= 0XF0;
         DiziRfidGelen[1] &= 0XF0;
         DiziRfidGelen[2] &= 0XF0;
         DiziRfidGelen[3] &= 0XF0;
         DiziRfidGelen[4] &= 0XF0;
         DiziRfidGelen[5] &= 0XF0;
         DiziRfidGelen[6] &= 0XF0;
         DiziRfidGelen[7] &= 0XF0;
         DiziRfidGelen[8] &= 0XF0;
         DiziRfidGelen[9] &= 0XF0;
         DiziRfidGelen[10] &= 0XF0;
         if(((((((((((DiziRfidGelen[0]^DiziRfidGelen[1])^DiziRfidGelen[2])^DiziRfidGelen[3])^DiziRfidGelen[4])^DiziRfidGelen[5])^DiziRfidGelen[6])^DiziRfidGelen[7])^DiziRfidGelen[8])^DiziRfidGelen[9])^DiziRfidGelen[10])==0){
            DiziOkunanEtiket[0]= DiziRfidGelen[0] | swap(DiziRfidGelen[1]);
            DiziOkunanEtiket[1]= DiziRfidGelen[2] | swap(DiziRfidGelen[3]);
            DiziOkunanEtiket[2]= DiziRfidGelen[4] | swap(DiziRfidGelen[5]);
            DiziOkunanEtiket[3]= DiziRfidGelen[6] | swap(DiziRfidGelen[7]);
            DiziOkunanEtiket[4]= DiziRfidGelen[8] | swap(DiziRfidGelen[9]);
            PinKartLed=1;
            if(    (DiziOkunanEtiket[0] != DiziOkunanEtiketOnceki[0]) ||
               (DiziOkunanEtiket[1] != DiziOkunanEtiketOnceki[1]) ||
               (DiziOkunanEtiket[2] != DiziOkunanEtiketOnceki[2]) ||
               (DiziOkunanEtiket[3] != DiziOkunanEtiketOnceki[3]) ||
               (DiziOkunanEtiket[4] != DiziOkunanEtiketOnceki[4])){
               DiziOkunanEtiketOnceki[0] = DiziOkunanEtiket[0];
               DiziOkunanEtiketOnceki[1] = DiziOkunanEtiket[1];
               DiziOkunanEtiketOnceki[2] = DiziOkunanEtiket[2];
               DiziOkunanEtiketOnceki[3] = DiziOkunanEtiket[3];
               DiziOkunanEtiketOnceki[4] = DiziOkunanEtiket[4];
               DiziRfidOkunan[0] = DiziOkunanEtiket[0];
               DiziRfidOkunan[1] = DiziOkunanEtiket[1];
               DiziRfidOkunan[2] = DiziOkunanEtiket[2];
               DiziRfidOkunan[3] = DiziOkunanEtiket[3];
               DiziRfidOkunan[4] = DiziOkunanEtiket[4];
               SayacPort1Giden=0;
      DurumBaslangic=0;
      for(Sayac=0; Sayac<11; Sayac++){
         DiziRfidGelen[Sayac]=0;
int   IDKontrol(char *p){
   if      ( *(p+1)==0X30  && *(p+2)==0X30 ){
      return   1;
   else if (E2CihazNo == (10*(*(p+1)-0X30) + (*(p+2)-0X30 ))){
      return   1;
   return   -1;
void   ChkSumHesapla(char *p){
   int   ChkSum=0;
   p++;
   do{
      ChkSum=ChkSum ^ *p;
   }while(*(++p) != 5);
   *(++p)=CevirAscii(ChkSum>>4 & 0X0F);
   *(++p)=CevirAscii(ChkSum&0X0F);
   *(++p)=3;
   *(++p)=13;
   *(++p)=10;
   *(++p)=0;
int   ChksumKontrol(char *p){
   int   i=1, ChkSumHesap, ChkSum=0;
   do{
      ChkSum = ChkSum ^ *(p+(i++));
   }while((*(p+i)!= 0X05) && i != 0 );
   ChkSumHesap =  swap(ChkSumDizi(*(p+(++i)))) | ChkSumDizi(*(p+(++i)));
   if(ChkSum == ChkSumHesap){   return   1;}
   return   0;
int   ChkSumDizi(int a){
   if(a<'A')   return a-0X30;
   return   a-0X37;
int   Ascii2Hex(int a){
   return   a-0X37;
int   CevirAscii(int a){
   if(a<10)   return   a + 0X30;
   return   a + 0X37;
void   Gecikme(void){
   delay_us(20);
char   SpiDataGonder(char GonderilenData){
   int   Sayac;
   char   AlinanData;
   SpiSclk=1;
   Gecikme();
   SpiMosi=0;
   Gecikme();
   SpiMosi=1;
   Gecikme();
   for(Sayac=7; Sayac!=(0-1); Sayac--){
      SpiSclk=0;
      Gecikme();
      if(   bit_test(GonderilenData, Sayac) == 1){
         SpiMosi=1;
      else{
         SpiMosi=0;
      Gecikme();
      SpiSclk=1;
      Gecikme();
      SpiSclk=0;
      Gecikme();
      SpiSclk=1;
      Gecikme();
      if( SpiMiso==1 ){
         bit_set(AlinanData, Sayac);
      else{
         bit_clear(AlinanData, Sayac);
      SpiSclk=0;
   SpiSclk=0;
   SpiMosi=1;
   return   AlinanData;
void   Htrc110Init(void){
   char   AlinanData;
   SpiDataGonder(0X16);
   delay_ms(5);
   SpiDataGonder(0b01001100);
   delay_ms(5);
   SpiDataGonder(0X50);
   delay_ms(5);
   SpiDataGonder(0X6C);
   delay_ms(5);
   SpiDataGonder(0X70);
   delay_ms(5);
   SpiDataGonder(0X8F);
   delay_ms(5);
   AlinanData=SpiDataGonder(0X04);
   AlinanData = AlinanData<<1;
   AlinanData = AlinanData+0X3F;
   AlinanData = AlinanData&0X3F;
   delay_ms(5);
   SpiDataGonder(0X80 | AlinanData);
   delay_ms(5);
   SpiDataGonder(0X6B);
   delay_ms(5);
   SpiDataGonder(0X68);
   delay_ms(5);
   SpiDataGonder(0X60);
   delay_ms(5);
char   Htrc110ReadTag(char GonderilenData){
   SpiSclk=1;
   Gecikme();
   SpiMosi=0;
   Gecikme();
   SpiMosi=1;
   Gecikme();
   SpiSclk=0;
   Gecikme();
   SpiMosi=1;
   for(Sayac=0; Sayac<3; Sayac++){
      Gecikme();
      SpiSclk=1;
      Gecikme();
      SpiSclk=0;
      Gecikme();
   SpiSclk=0;
   delay_ms(1);
   enable_interrupts(INT_RAB);
   return   0;   // Bu andan itibare SpiMiso pininde sürekli sadece tag data var
void   Htrc110ReadSet(void){
char   AlinanData;
   AlinanData=SpiDataGonder(0X07);
   fprintf(PORT1, "PAGE 3 =%2X\X0D\X0A", AlinanData);
   AlinanData=SpiDataGonder(0X06);
   fprintf(PORT1, "PAGE 2 =%2X \X0D\X0A", AlinanData);
   AlinanData=SpiDataGonder(0X05);
   fprintf(PORT1, "PAGE 1 =%2X \X0D\X0A", AlinanData);
   fprintf(PORT1, "PAGE 0 =%2X \X0D\X0A", AlinanData);
   AlinanData=SpiDataGonder(0X03);
   fprintf(PORT1, "%2X \X0D\X0A", AlinanData);
   AlinanData=SpiDataGonder(0X02);
   fprintf(PORT1, "Sample Time =%2X \X0D\X0A", AlinanData);
        SET_TRIS_A(0b01111111);
        SET_TRIS_B(0b00110000);
        SET_TRIS_C(0b00000000);
   IOCB   =0b00010000;
   PinKartLed=1;
   PinRunLed=1;
   PinKartLed=0;
   PinRunLed=0;
   sprintf(DiziPort1Giden, "\X02%02uStartPort1\X05", E2CihazNo);
   Htrc110Init();
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_64);
   enable_interrupts(INT_RDA);
   while(TRUE){
MKY
PostPosted: Sat Apr 25, 2015 12:05 pm     Reply with quote
I read some 125 kHz tag distance 15 - 20 cm, coil 600- 700 uH
( Htrc ile ilgiili çok kod aradım ama işe yarar pek bir şey bulamadım.
Arayıpda bulamayanlar buradan faydalanabilir)
Translation:
( I searched for a lot of code for HTRC but couldn't find anything that
works. Those who searched but could not find it can benefit from here)
