Can one turn off the PCW auto screen positioning?
icefield
PostPosted: Fri Sep 03, 2010 9:51 am     Reply with quote
The PCW window likes to stick into corners when the window is moved around on the screen. However this is implemented, it does not play nicely with my multiple monitor manager. Is there a way to turn off this behaviour?
I'm not sure what impels programmers to deviate from standard interface behaviour, but this is an example of someone spending a lot of time on something that ends up causing problems...
I could not find anything in the "Editor properties" menu.
PostPosted: Fri Sep 03, 2010 11:59 am     Reply with quote
I don't have the CCS IDE, but the manual lists this setting in the View menu:
Dock
Editor
Window
Selecting this checkbox will dock the editor window into the IDE.
You probably have it enabled.
