XOR and data types question
dgoldman
PostPosted: Wed Sep 01, 2010 9:58 am     Reply with quote
I am using PCWH v3.218 for a project on an 18f452 and all is good.
Same code breaks on v4.112. I have found the issue to be related to xor and data types.
Test #1 is standard xor truth table.
Test #2 was what my code was doing (ok in 3.218 and not in 4.112).
Why are there differences in Tests 3 and 4?
Why doesn't test 2 work in the new compiler?
Anyone got clues? It would be appreciated.
Am I am missing something simple here?
int1 check()
   unsigned int1 c;
   unsigned int1 q;
   unsigned int32 k;   // this data type is needed for other purposes and cannot easily be changed.
   signed int32 j;        // this data type is needed for other purposes and cannot easily be changed.
   fprintf(DEBUG_STREAM, "XOR test 1 - works\r");
      c = 0;  c ^= 0;  fprintf(DEBUG_STREAM, "0 ^ 0 = 0X%X\r", c);
      c = 1;  c ^= 0;  fprintf(DEBUG_STREAM, "1 ^ 0 = 0X%X\r", c);
      c = 0;  c ^= 1;  fprintf(DEBUG_STREAM, "0 ^ 1 = 0X%X\r", c);
      c = 1;  c ^= 1;  fprintf(DEBUG_STREAM, "1 ^ 1 = 0X%X\r", c);
      fprintf(DEBUG_STREAM, “\r");
   fprintf(DEBUG_STREAM, "XOR test 2 - doesn't work\r");
      k = 0; c = 0;  c ^= ((int1)k);  fprintf(DEBUG_STREAM, "0 ^ 0 = 0X%X\r", c);
      k = 0; c = 1;  c ^= ((int1)k);  fprintf(DEBUG_STREAM, "1 ^ 0 = 0X%X\r", c);
      k = 1; c = 0;  c ^= ((int1)k);  fprintf(DEBUG_STREAM, "0 ^ 1 = 0X%X\r", c);
      k = 1; c = 1;  c ^= ((int1)k);  fprintf(DEBUG_STREAM, "1 ^ 1 = 0X%X\r", c);
   fprintf(DEBUG_STREAM, "XOR test 3 - doesn't work\r");
      k = 0; q=k; c = 0;  c ^= q;  fprintf(DEBUG_STREAM, "0 ^ 0 = 0X%X\r", c);
      k = 0; q=k; c = 1;  c ^= q;  fprintf(DEBUG_STREAM, "1 ^ 0 = 0X%X\r", c);
      k = 1; q=k; c = 0;  c ^= q;  fprintf(DEBUG_STREAM, "0 ^ 1 = 0X%X\r", c);
      k = 1; q=k; c = 1;  c ^= q;  fprintf(DEBUG_STREAM, "1 ^ 1 = 0X%X\r", c);
   fprintf(DEBUG_STREAM, "XOR test 4 - works\r");
      k = 0; q=k; c = 0;  c = c ^ q;  fprintf(DEBUG_STREAM, "0 ^ 0 = 0X%X\r", c);
      k = 0; q=k; c = 1;  c = c ^ q;  fprintf(DEBUG_STREAM, "1 ^ 0 = 0X%X\r", c);
      k = 1; q=k; c = 0;  c = c ^ q;  fprintf(DEBUG_STREAM, "0 ^ 1 = 0X%X\r", c);
      k = 1; q=k; c = 1;  c = c ^ q;  fprintf(DEBUG_STREAM, "1 ^ 1 = 0X%X\r", c);
   fprintf(DEBUG_STREAM, "XOR test 5 - doesn't work\r");
      k = 0; c = 0;  c = c ^ k;  fprintf(DEBUG_STREAM, "0 ^ 0 = 0X%X\r", c);
      k = 0; c = 1;  c = c ^ k;  fprintf(DEBUG_STREAM, "1 ^ 0 = 0X%X\r", c);
      k = 1; c = 0;  c = c ^ k;  fprintf(DEBUG_STREAM, "0 ^ 1 = 0X%X\r", c);
      k = 1; c = 1;  c = c ^ k;  fprintf(DEBUG_STREAM, "1 ^ 1 = 0X%X\r", c);
   fprintf(DEBUG_STREAM, "XOR test 6 - works\r");
      k = 0; c = 0;  c = (c != k);  fprintf(DEBUG_STREAM, "0 ^ 0 = 0X%X\r", c);
      k = 0; c = 1;  c = (c != k);  fprintf(DEBUG_STREAM, "1 ^ 0 = 0X%X\r", c);
      k = 1; c = 0;  c = (c != k);  fprintf(DEBUG_STREAM, "0 ^ 1 = 0X%X\r", c);
      k = 1; c = 1;  c = (c != k);  fprintf(DEBUG_STREAM, "1 ^ 1 = 0X%X\r", c);
   return 0;
This results in:
XOR test 1 - works
0 ^ 0 = 0X00
1 ^ 0 = 0X01
0 ^ 1 = 0X01
1 ^ 1 = 0X00
0 ^ 0 = 0X00
1 ^ 0 = 0X00
0 ^ 1 = 0X01
1 ^ 1 = 0X01
0 ^ 0 = 0X00
1 ^ 0 = 0X00
0 ^ 1 = 0X01
1 ^ 1 = 0X01
XOR test 4 - works
0 ^ 0 = 0X00
1 ^ 0 = 0X01
0 ^ 1 = 0X01
1 ^ 1 = 0X00
0 ^ 0 = 0X00
1 ^ 0 = 0X00
0 ^ 1 = 0X00
1 ^ 1 = 0X00
XOR test 6 - works
0 ^ 0 = 0X00
1 ^ 0 = 0X01
0 ^ 1 = 0X01
1 ^ 1 = 0X00
dgoldman
PostPosted: Wed Sep 01, 2010 1:56 pm     Reply with quote
By changing c from an unsigned int1 to an unsigned int32, all now works.
No casting of k, just c ^= k.
Still doesn't make a whole lotta sense but things are working.
