symbol map menu item ghosted?
equack
PostPosted: Sun Aug 29, 2010 10:50 am     Reply with quote
In my IDE (version 4.111) the "View->Symbol Map" menu item used to work fine but now it is ghosted. I can still view the symbol map by manually loading the ".sym" file into the editor.
Did I accidentally disable the menu item somehow? What can I do to restore it?
dyeatman
PostPosted: Sun Aug 29, 2010 11:07 am     Reply with quote
I would try a uninstall/reinstall.
Mine is in a different place under Compile->Symbol Map but it works fine in 4.111.
Google and Forum Search are some of your best tools!!!!
Herbert
PostPosted: Fri Sep 03, 2010 8:37 pm     Reply with quote
I have had this problem since I installed PCWH 4.105. Till now it hasn't bothered me. But that has changed. I have done a reinstall of 4.105 and there is no change.
Are there any other thoughts on why "Symbol Map" is ghosted out? Thanks.
Herbert
PostPosted: Sat Sep 04, 2010 6:40 am     Reply with quote
Had a thought, I do notice I didn't have "ideutils" loaded for the 4.105 version. So I dug out the version for 4.101 and installed that (somehow managed to miss on downloading the version that went with 4.105). Did not make a difference to the ghosting. Do I need "ideutils" for 4.105 to get rid of the ghosting? Or am I looking in the wrong place?
dyeatman
PostPosted: Sat Sep 04, 2010 7:04 am     Reply with quote
I honestly don't know why the item is ghosted but I always download the
compiler and utils and store them as a set then install them as a set.
Herbert
PostPosted: Sat Sep 04, 2010 10:09 pm     Reply with quote
Yep, just plain forgot to download that part and it had no immediate impact on me.
I have gone back to a full install of 4.001 and there is exactly the same ghost problem. And that is with the ideutils for that version installed.
dyeatman
PostPosted: Sun Sep 05, 2010 4:06 am     Reply with quote
Sounds like time to send an email to CCS tech support...
