delifadzli
Clarification on my code |
Posted: Fri Aug 27, 2010 11:22 am |
Can someone check whether this code is true or not...the situation is for 2 sensor. The sensor alert from 1 to 2 will result = increment 1 while if the sensor 2 followed by 1 will result = decrement 1. The objective is to make the entire system operate as the counter increase, except if the counter equal to zero...the output will be low. Sorry for my weakness... I had try to solve it...but still don't what the problem.
Can someone help me?
#include <16F877A.H>
#device ADC=10
#FUSES HS,NOWDT,NOPROTECT,NOLVP //high speed osci >4Mhz, No watch dog timer,
#USE DELAY(CLOCK=20000000) //must use if not cannot use delay_ms, instruct the microcontroller's speed
//#include <stdio.h>
#include "E:\note ngaji\FYP\stuff last sem\code\Batu\brum\Flexlcd2.c"
#define LED1 PIN_D7
#define LED2 PIN_D6
#define exit PIN_C7
#define exit2 PIN_C6
#define zero PIN_C5
int inout_counter=0,PIR1,PIR2,in,out;
int16 counter1;
//unsigned char ole;
//int v;
lcd_init();
lcd_putc("\fcounter people:\n");
{ PIR1=0;
PIR2=0;
in=0;
out=0;
lcd_gotoxy(1,2);
printf(lcd_putc,"%d",inout_counter);
PIR1 = input(PIN_D5);
PIR2 = input(PIN_D4);
if(PIR1==1)
output_high(exit); // indication sensor 1 alert
for(counter1=10000;counter1>0;counter1--)
delay_ms(1);
if(PIR2==1)
in=1;
if(in==1)
inout_counter++;
else if(PIR2==1)
output_high(exit2); //indication sensor 2 alert
delay_ms(1);
if(PIR1==1)
out=1;
if(out==1)
inout_counter--;
if(inout_counter>0)
output_high(LED1); //desired output
output_low(LED2);
output_high(LED2);
output_low(LED1);
output_low(exit);
output_low(exit2);
output_high(zero); // to indicate all system off..
Posted: Fri Aug 27, 2010 12:16 pm |
First a few general remarks. You are getting low response because your code is difficult to read:
- Set your editor to use spaces instead TAB characters. The TAB character is a different size on many systems and now the layout of your code is jumping around.
- Be consequent in the usage of small and capital letters. Common practice is to write only constants in all capital words. Variables are then in all small letters or a combinations of capitals and small letters.
so good: Code: | #define LED1 PIN_D7
int inout_counter=0,in,out; | bad: Code: | #define exit PIN_C7
int PIR1,PIR2; |
Then a real problem: Code: | for(counter1=10000;counter1>0;counter1--)
pir2 = input(SENSOR2);
delay_ms(1);
if (pir2==1)
in=1;
} | 10,000 times 1ms = 10 seconds.
Your detection is busy for 10 seconds before it can start detecting a new person.... You didn't mention the distance between the two sensors, but this seems like a long time.
If you still have problems, then describe what you are seeing. What actions do you make and what is the response to the LEDs and display? |
delifadzli
Posted: Fri Aug 27, 2010 7:43 pm |
Both sensors will be placed at the door, one at the entry of the door and the other one just behind it.
The action that I planned:
The sensor 1 will be off first before checking for sensor 2.
The same goes for decrement action.
The problem is, if the sensor 1 detected, the output will go low.
What I want is, the system only respond to the counter value. If counter = 0, the LED1 off, else it will on (Counter>0 , LED1 ON).
Then, for this one:
#define exit PIN_C7
int PIR1, PIR2;
I don't understand. Sorry for my weakness. |
