I have some bug on "RDA interrupt"
sindyme
PostPosted: Thu Aug 26, 2010 9:06 pm     Reply with quote
I have a bug on "PIC24FJ256GA106"
When I open two "int_RDA" that PIC will work normal.
But if I open third "int_RDA" (int_RDA, int_RDA2, int_RDA3) that PIC will not work.
Who can help me to solve this bug ?? I'm very thanks Very Happy
Here is my code of .h file & .c file
#include <24FJ256GA106.h>
#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PR                       //Primary Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES WPFP
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=24000000)
#pin_select U1TX = PIN_G6        //coma
#pin_select U1RX = PIN_G7
#pin_select U2TX = PIN_B14       //comb
#pin_select U2RX = PIN_B15
#pin_select U3TX = PIN_D8       //comc
#pin_select U3RX = PIN_D9
#use rs232(UART1,baud=9600,parity=N,bits=9,LONG_DATA,stream=coma)
#use rs232(UART2,baud=115200,parity=N,bits=8,stream=comb)
#use rs232(UART3,baud=115200,parity=N,bits=8,stream=comc)
#int_RDA
void  RDA_isr()
   rs_buff[buff_number] = getc(coma);
   if(buff_number<32)
      buff_number=buff_number+1;
      buff_number=0;
#int_RDA2
void  RDA2_isr()
   //TestP = getc(comb);
   //fprintf(comb,"%c",TestP);
   rs_buffb[buff_numberb] = getc(comb);
   if(buff_numberb<128)
      buff_numberb=buff_numberb+1;
      buff_numberb=0;
#int_RDA3
void  RDA3_isr()
   rs_buffc[buff_numberc] = getc(comc);
   if(buff_numberc<64)
      buff_numberc=buff_numberc+1;
      buff_numberc=0;
   delay_ms(200);
   setup_spi(FALSE);
   setup_spi2(FALSE);
   setup_wdt(WDT_ON);
   setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
   enable_interrupts(INT_RDA3);
   for(;;)
        my code XXXXXX
PostPosted: Fri Aug 27, 2010 1:14 am     Reply with quote
How do you know UART3 is not working?
To rule out hardware problems. What happens when you shuffle the pins around so that UART 2 and 3 are switched? Does UART 2 then stop working?
PIC24 is new for CCS, so you might have stumbled upon a bug.
Always post your compiler version number. It might be a known (and fixed) problem.
Extra advice: study the ex_sisr.c example code for how you could implement an interrupt driven receiver routine using a circular buffer. This has proven to be one of the better methods for serial data reception.
